Directly from their website:
We recommend the use of Briggs & Stratton Warranty Certified oils for best performance. Other high-quality detergent oils are acceptable if classified for service SF, SG, SH, SJ or higher. Do not use special additives.
Outdoor temperatures determine the proper oil viscosity for the engine. Use the chart to select the best viscosity for the outdoor temperature range expected. Engines on most outdoor power equipment operate well with 5W30 Synthetic oil. For equipment operated in hot temperatures, Vanguard 15W50 Synthetic oil provides the best protection.
-Use SAE 30 in warmer temperatures of 40° F and higher (5° C and higher)
-Use SAE 10W-30 for a varying temperature range of 0 to 100° F (-18 to 38° C), this grade of oil improves cold weather starting, but may increase oil consumption at 80° F(27° C) or higher
-A synthetic oil SAE 5W-30 is the best for very cold temperatures of -20 to as high as 120° F (-30 to 40° C) providing the best protection at all temperatures as well as improved starting with less oil consumption
-Use SAE 5W-30 for very cold temperatures of 40° F and below (5° C and below)
-For continuous-use, such as commercial lawn cutting or pressure washing, use Vanguard 15W-50 Oil (temperatures from 20°F to 130°F)
-Use a high quality detergent oil classified "For Service SF, SG, SH, SJ" or higher.
-Do not use special additives.
-Synthetic oils are an acceptable oil at all temperatures. Use of synthetic oil does not alter required oil change intervals.
