2007 Camry LE I4.
So for a little while now there has been a chugging sound coming from around the drive belt area. So far, I have been unable to locate the specific cause of the noise, but it is starting to drive me INSANE.
The car idles, runs, and drives fine. There are no signs of overheating or anything negative. Other than the noise itself, everything appears to be normal. It seems to do it after the car has warmed up just a bit, and you can only hear it between idle and under 20 mph. It seems to increase in frequency when moving, but it is difficult to tell.
So, my thought is that it could be the water pump, oil pump, one of the pulleys, the serpentine belt (which appears to be fine... no cracks or wear that I can see), the AC compressor (AC and heat work just fine), or who knows I just need it to stop before I set the car on fire.
I have psted two videos, one from inside and one from outside the car. Have any of you heard this type of noise before? Any idea what it could be? Figured I would ask here first before I started replacing things.
Thanks!
Thanks!
