1979 300sd
Hard to brake and brake pedal feels mushy.
Pedal does not travel to floor when at a stand still so I don't think its the Master Cylinder(MC)
Just replaced the front/rear calipers, rotors and brake hoses.
Bled the brake lines using my motive brake bleeder.
Used Dot 4 brake fluid by Napa.
Started at the rear passenger side brake caliper and continued to move to the rear drivers side caliper, then to the front passenger side caliper and finally moving on to bleed the drivers front caliper.
Are these signs of a bad brake booster or a bad Master Cylinder?
Am I using the right brake fluid?
Should I switch brake fluids before looking at what else might be wrong?
Car had not been driven since September of 2015.
I actually think that the brakes today feel like the brakes from back in Sep 2015.
Just seems odd that I have to press on the brake pedal so hard with all new calipers, rotors and brake hoses.
I once read a post where some guy switched to a different brake fluid ( same Dot) and this ended up correcting the problem
Please advise
Please advise
