The Blend Door Actuator in my sister's 2005 Freestyle is Clicking, and needs replaced. they took it to their local indie, and he said it was an inexpensive part(it is), but the labor would be huge b/c the dash has to come out.(totally wrong)
the part in question is directly behind the glovebox, and it's a 15 min fix max.
there are at least 3 different actuators with similar but different part numbers in the dash (automatic, dualzone setup, one for the recirc door, one for each of the front zones, etc.) each of which it seems has been replaced or superseded with revised parts, and the alphabet soup of the nearly identical part numbers is making me go crosseyed.
the one in question is the recirc door actuator, all the way to the right of the car.
the installed defective(Factory) unit has the following numbers on it:
5F93-19E616-CA
VP5F9H-19E616-CA
There seem to be at least 5 different 19E616's listed, each with a different part number attached(YH-1864, YH-1865, YH-1866, etc)
I need an assist from someone familiar with ford's parts systems(paging BDCardinal) as I want to use real Ford Parts.
(recently had to do the same job on my sable for the second time in 2 years, bought a dorman unit the first time, broke almost exactly a year later.) Sable has a slightly different system, different numbers, etc.
also in Dropping the Glovebox to to determine the proper actuator, I forgot to disconnect the damper from the left side, and snapped it's retainer in half(the white pushpin one in the dash.)
gonna need a part number for that too... unless I just have to buy the whole "Glove Box Door Check" as ford seems to want to call it...
5F93-19E616-CA
VP5F9H-19E616-CA
