I'm only 200 miles into this OCI, but I've already noticed two things about this oil in my car versus the Delo that was in it previously.
Firstly, the engine seems to operate a little smoother on the Kendall than with the Delo, so much so that I haven't felt the need to add any MoS2 this go around.
Secondly, it seems it might be a bit thinner than the Delo. Both are SAE 30, but my cold and hot oil pressure readings are slightly lower with the Kendall than the Delo, but not by much.
I cannot comment on consumption at the moment, but this engine has previously consumed no discernable amount of both QS 20W-50 or Delo 400 30 that were its two previous fills.
If anyone is interested, which I doubt you are, I'll be updating this on occasion.
