Fastest MIR ever!
by parshisa
02/22/18 02:40 PM
2003 Dodge Dakota 4.7 V8 5-speed manual 4X4
by oilpsi2high
02/22/18 02:28 PM
Eagles are one and done..
by LeakySeals
02/22/18 02:20 PM
Switching Oil viscosity giving Quicksilver a try
by ad244
02/22/18 01:54 PM
2015 Yaris oil recommendation
by BIMMA
02/22/18 01:29 PM
Can any one tell me who make's this air filter?
by rollinpete
02/22/18 01:17 PM
38 years ago today
by dnewton3
02/22/18 01:07 PM
PQIA - Havoline HM Synblend 5w-30
by wemay
02/22/18 12:44 PM
Any 2015 Corolla owners here - coolant change Q
by NissanMaxima
02/22/18 12:20 PM
Thoughts on 2007 Hyundai Azera for $2700
by 901Memphis
02/22/18 12:18 PM
run straight coolant
by slomo
02/22/18 11:43 AM
How much liquid is needed to hydrolock an engine?
by zorobabel
02/22/18 11:14 AM
Intake manifold bolts torque 11ft lb
by Ndx
02/22/18 10:55 AM
Orange can of death
by WyrTwister
02/22/18 10:42 AM
Weird Master Cylinder Behavior
by artbuc
02/22/18 10:42 AM
Police were called, I was shoplifting!
by expat
02/22/18 10:41 AM
Mobile CI-4+ in Cummins 5.9L
by MileHi
02/22/18 10:19 AM
How & what pistol do you carry concealed?
by callbay
02/22/18 10:13 AM
High Mileage Transmission Change
by toreytlow
02/22/18 10:13 AM
Jamison Guardian Ammo
by BlueOvalFitter
02/22/18 09:53 AM
toreytlow, KOlan, Tenorman, DMperfection101, WiseOne
64257 Registered Users
108 registered (4WD, 2010Civic, 69Torino, 14Accent, 69GTX, 7 invisible), 1723 Guests and 95 Spiders online.
64257 Members
65 Forums
278546 Topics
#4325651 - 02/10/17 01:49 AM Cruze Diesel Mobil 3000 XE
jkhawaii Offline
Loc: Oahu
#4325653 - 02/10/17 01:59 AM Re: Cruze Diesel Mobil 3000 XE [Re: jkhawaii]
jkhawaii Offline
Loc: Oahu
Last change was AC delco Dexos 2, first was unknown (might have been Dexos 1) been running biodiesel blends between 10-20%. It doesn't show but, there was some fuel dilution on the last two samples (oil level above full)
I have backed down to a B5 blend, will see how it goes
#4325731 - 02/10/17 07:29 AM Re: Cruze Diesel Mobil 3000 XE [Re: jkhawaii]
bigt61 Offline
Loc: Virginia
Looks good - what's your usage profile - city - highway - idling?
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#4325834 - 02/10/17 09:32 AM Re: Cruze Diesel Mobil 3000 XE [Re: bigt61]
jkhawaii Offline
Loc: Oahu
Lots of traffic here on the island of Oahu. Driving distance is usually less than 20 miles a day.
#4326370 - 02/11/17 04:53 AM Re: Cruze Diesel Mobil 3000 XE [Re: jkhawaii]
Jetronic Offline
Loc: down in the park
What year is your cruze diesel? there's 3 completely different engines (all 2.0 litres) depending on the year of manufacture. A VM motori, a GM/daewoo and lastly a Fiat.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
#4326495 - 02/11/17 09:31 AM Re: Cruze Diesel Mobil 3000 XE [Re: Jetronic]
jkhawaii Offline
Loc: Oahu
In the USA there was only one Diesel engine. I Beleve the VM motori. It's a 2014
#4326554 - 02/11/17 10:51 AM Re: Cruze Diesel Mobil 3000 XE [Re: jkhawaii]
Jetronic Offline
Pictures I've seen all show the fiat engine now. Including pictures here.
Is the oil drain on the right side of the engine? the oil filter is on the same side aswell.
#4326678 - 02/11/17 01:14 PM Re: Cruze Diesel Mobil 3000 XE [Re: jkhawaii]
alex_at Offline
Loc: Vienna, Austria
wether it's a VM Motori or a Fiat Diesel engine, both are one of the best Diesel engines I ever owned.
I had a 2.7 L VM Motori in a Mercedes W210 270CDI and several Fiat Diesel's from 1.9 to 2.4 L -> they are very common to reach 500.000km without major issues.
The most issues I had with Diesel engines were Volkswagen/Audi Diesel's 2.7 and 3.0 TDI engines.
Edited by alex_at (02/11/17 01:14 PM)
#4339754 - 02/25/17 07:51 PM Re: Cruze Diesel Mobil 3000 XE [Re: jkhawaii]
BobFout Offline
Loc: Indiana
Where did you find Mobil Super 3000 XE 5W-30 for sale in the US? For an oil that starts at ~12 cSt, it's sheared some.
2003 VW Jetta TDI (Sold) / 2015 VW GTI 2.0T
#4340348 - 02/26/17 12:25 PM Re: Cruze Diesel Mobil 3000 XE [Re: BobFout]
edyvw Online   content
Loc: Colorado Springs
Too much shear for C3 oil.
Move to Mobil1 5W30 ESP or some other similar oil.
13' BMW X5 35d (Mobil1 5W30 ESP+OEM filter)
11' VW Tiguan 2.0T (Castrol 0W40+OEM filter)
#4340981 - 02/27/17 09:14 AM Re: Cruze Diesel Mobil 3000 XE [Re: edyvw]
jkhawaii Offline
Loc: Oahu
I will be using Valvoline Synpower MST. I belevied it was fuel dilution causing the viscosity reduction but, the last test showed no fuel. Perhaps Blackstones fuel percentage is off? I have been running a Biodiesel blend. First sample was b20 second b10. Currently running a B5 blend. I beleave the fuel reading is off. The oil level was higher at 4000 miles than at the time of oil change
#4342244 - 02/28/17 03:37 PM Re: Cruze Diesel Mobil 3000 XE [Re: jkhawaii]
Bobby_x Offline
Loc: Poland
Have you got dpf?
Cleaning it out requires extra fuel to be injected and eventually burned in dpf.
It also causes high oil level.
Typical for city driving.
Bobby
07 Yaris 1.3 vvti mix of 5w30 + Alco sp-991 filter
#4346480 - 03/05/17 08:07 PM Re: Cruze Diesel Mobil 3000 XE [Re: Bobby_x]
jkhawaii Offline
Loc: Oahu
Originally Posted By: Bobby_x
Have you got dpf?
Yes has DPF. Suspect Biodiesel blend causing more fuel dilution than normal
