Own a 1979 300sd and will be replacing the water pump and fan clutch.
I already removed the old water pump and fan clutch
I observed blue caulking along with the old paper gasket still on the water pump seat.
Is to necessary to use caulking or sealer?
The water pump from the dealer came with a paper gasket and bolts.
Also not sure which of the paper gasket goes on what.
Does the lettering on the gasket face the engine or does it face the fan clutch?
What is the best way to clean the seat or the joint between the engine and the water pump?
There isn't much residue from the paper gasket and caulking on the seat but I would like to leave that surface super clean.
Any advice is greatly appreciated
