Originally Posted By: oil_film_movies
Originally Posted By: Shannow
Yes, the rings DO get that hot...in the reversal zone, it's boundary and mixed, which is additive, not viscosity dependent.
Getting higher viscosity on those hot rings means less boundary/mixed.
And, the less boundary/mixed you have, the less wear and friction.
That's what Mobil and racers are doing.
Actually, it's pretty hard to avoid boundary/mixed in the ring reversal area, as the velocity passes through zero (there goes hydrodynaimc).
You've fallen into the common trap about wear and friction.
In boundary/mixed, the co-efficient of friction is typically lower with the presence of FMs, while the wear is a little higher...as the oil film gets thicker, wear goes down, but friction goes up.
The mind trap is pretty common when people talk ILSAC...less friction doesn't mean less wear.
I'd be most surprised if F1 engineers were increasing viscosity top protect the top rings, as that would be around a horsepower wasted for nothing....they don't race 200,000 miles (usually).
