castrol edge euro (made in belgium if that matters) 0w-40 with MANN filter. MANN air filter too.
I haven't seen many e46 UOA and i'm not sure how to interpret my UOA. This oil seen some diverse use, It's been in since august and seen a 50/50 use in highway/city driving. The highway miles were hard miles...many 4+ hour trips at 80-90mph, with the gearing my car has that's around 3500-4000 rpm. This oil also seen about a month of -20 to -40 below starts.
iron seems high yes? lifters can be noisey at times, could lifter wear produce higher iron? Should i shorten oil changes to 5k?
should i consider a different air filter? I replaced the valve cover and gasket with light RTV about 20k ago..
Thanks for any input.
