Originally Posted By: Garak
ACEA E7, E9 oils aren't that uncommon, and there are such products even in 15w-40 conventionals. And,
E4 is obsolete.
WT*%#§??? NO! E4 IS NOT obsolete! Please take a look at this:
ACEA oil sequences DECEMBER 2016
You will notice I made a wrong claim too, by indicating that E6 might not be more demanding than E4. As opposed to E4, E6 actually requires to pass the Mack T10 or T12 test on an ACEA E7 level, but most E4 oils these days are E4/E7 dual rated anyway. ACEA E4 continues to define the core performance level for several European LONG DRAIN (sometimes aka UHPD) specifications, such as MB228.5, MTU TYPE 3 and Deutz DQC-IV-10, especially in terms of TBN 12 and piston cleanliness in the “new” OM501LA or in the “old” OM441LA engine test. Their Low SAPS counterparts are ACEA E6, MB 228.51, MTU TYPE 3.1 and Deutz DQC-IV-10LA and logically, E6 has no TBN 12 requirement. While MAN’s “normal SAPS” UHPD specifications (M3277 and M3377) appear to be exempted from the TBN rule, they still demand the higher level of piston cleanliness found in E4. Pre CJ-4 mineral HDEOs hardly ever provided an UHPD level of piston cleanliness. Mobil however claimed that Delvac MX 15w-40 CI-4+/SL (not the European Gr. I CI-4/SL) exceeds the E4 limit in the older OM441LA. Gr. I-only ACEA E7 HDEOs cannot - not at all! A number of mineral or syn blend CJ-4/E9 oils have the potential to, but the only claims I have seen are from Shell, for their Rotella T5 and Rimula R5 LE. CK-4 could change everything though. Regarding this OM646LA outlet cam wear test, plenty of E6 product/marketing literature proudly presents results in the 40 – 50 micron ball park and nobody expects CI-4/E7 or CJ-4/E9 oils to exceed the E4/E6 limit - even A5/B5 are supposed to beat the 120 micron mark. All that said, I wish to emphasize that ACEA E7 and E9 are not universally better than E4. Oil specifications can coexist, be mutually exclusive, or complement each other.
Yes, Delvac 1 5w-40 and Delvac 1 ESP 5w-40 are remarkable products, but that's really not the point
You are suggesting that ACEA E6 oils like Delvac 1 LE 5w-30 CJ-4 are superior to Delvac 1 ESP, or at least to most CJ-4/E7/E9 HDEOs, because of their longer list of approvals, which happen to be nothing but ACEA E6 based approvals. The demanding part of these specifications (piston cleanliness) can basically be met by Delvac 1 CI-4+ (because of the E4 performance) and by Delvac 1 ESP CJ-4 (confirmed by the MAN M3277 and M3377 approvals). So
YES, IT IS THE POINT, especially if people believe that it takes CJ-4/E6 or CK-4/E6 to "enjoy" an ACEA E4 or UHPD performance level! I will say though, that the lower amount of VIIs in the 5w-30 will help control turbo charger deposits, which is quite a hurdle if you want to step up to a Deutz DQC-
IV-10LA level. DQC-IV-10 wants it even cleaner. Neither list ever had a 5w-40. Delvac 1 ESP CK-4 is almost a 5w-30 and has received an ashless TBN boost, so if Mobil has done a real good job, it has a potential for Deutz DQC-IV-10, but I have my doubts, because the reformulation was a wonderful opportunity to move to a cheaper basestock blend.
