Oil weight
Originally Posted By: gilbertsta
I found a great deal on a bunch of 50w oil.
If it is Schaeffers 5W-50 you can sell it to me. I love running the thicker oil in my Beetle, especially since it has a bad camshaft (and needs the extra thickness for protection). In fact all 2005-06 TDIs have this problem and need a thicker oil.
But to answer your question: Mix Mobil 0W-20 with your 50W-50 oil, and the viscosity modifiers will thin it down to approximately 10W-50 oil. (In other words the topend will not change, but the bottom end will.)
Amazing. I hadn't realized you had access to CCS and MRV testing equipment, thanks for the share!
Don't feed the troll sir OVERKILL
And apparently ISO 4548- testing equipment for researching oil filter efficiencies.
No I just emailed Purolator, Mobil, and others so I could ASK for their testing results.
I find that your statement regarding thinner oil not changing the 50 part pretty interesting in the extreme...whose suggestion was that oils behaved THAT way ?
Did you get efficiency stats from ExxonMobil? If so, what were they?
This was years ago..... so no I don't have the emails from mobil1.com. I remember being surprised M1 filters do not remove dirt as well as standard non-extended drain filters, and then regretted buying a whole box of them.
Well, you got a unique response then.
Okay I called Fram & Mobil whose respective techs told me the Fram Ultra filter is:
99% at 25
98% at 20
50% at 10 (aka nominal)
Mobil only listed 25 microns, which they rate at 97%. So it's worse. (Like I said.) If you don't believe me you could pick-up your phone & call them yourself.
