OVERKILL
$100 Site Donor 2021
Originally Posted By: Wolf359
Mercedes and others generally have lots of tech that can fail. Also if they're only going up to 2012, that probably covers the Mercedes M272 engine which came out in 2004 and up to about 2007 had bad balance shafts and just going by the serial numbers, could have affected almost 470k engines. Repair costs were in the $4-7k range because you had to take the engine out to replace the balance shafts which were only a few hundred dollars. People who don't know any better are still buying cars from that age and running into that problem, problem could appear anywhere from 40-120k. I still see ads online from people who claim that the car runs fine but there's a CEL light on and they assume it's nothing, but they must really know that it's a sign the engine is starting to go and it will only get worse over the next few thousand miles.
Mercedes was 3rd in the TOP 10 part of the list, as in they had the third LOWEST failure rate.
