Been using PUP 5w30 since new and oem filter. Oil changes @ 1500, 3000, 5000, 10000, 15000
Blackstone remarks:
Subaru might call for 0W/20 oil, but we don't see any issues as a result of having 5W/30 in place
instead. This oil is working well for your FB25 engine, as you can see by the amount of metal that's present.
Universal averages show typical wear after about 6,000 miles of oil use, and these numbers compare well.
Copper is a bit elevated, but that's probably just residual wear-in material that's still washing out. It's often
the last metal to wash out completely. It may improve, but if not, this reading is fine. The TBN was strong at
4.5 since 1.0 is low - lots of active additive left.
Lab: Blackstone
Miles on oil: 4,855
Miles on engine: 14,782
Sample date: 1/4/2017
Report date: 1/11/2017
Makeup oil added: 0
Aluminum 2
Chromium 0
Iron 5
Copper 7
Lead 0
Tin 0
Molybdenum 46
Nickel 0
Manganese 0
Silver 0
Titanium 2
Potassium 2
Boron 53
Silicon 18
Sodium 2
Calcium 1949
Magnesium 13
Phosphorous 558
Zinc 689
Barium 0
SUS Viscosity @ 210* F = 58.9
cSt Viscosity @ 100* C = 9.91
Flashpoint in * F = 445
Fuel % = Antifreeze % = 0.0
Water % = 0.0
Insolubles % = TR
TBN = 4.5
Blackstone remarks:
Lab: Blackstone
Miles on oil: 4,855
Makeup oil added: 0
Aluminum 2
Chromium 0
Iron 5
Copper 7
Lead 0
Tin 0
Molybdenum 46
Nickel 0
Manganese 0
Silver 0
Titanium 2
Potassium 2
Boron 53
Silicon 18
Sodium 2
Calcium 1949
Magnesium 13
Phosphorous 558
Zinc 689
Barium 0
Water % = 0.0
Insolubles % = TR
TBN = 4.5
