Originally Posted By: ffhdriver
Thanks for the info,but my OEM blades are the beam type which aren't refillable. I of course could change to the kind you mention.
There are 2 types of beam blades from Toyota. The first type is the one from the factory that has replaceable inserts. The second type is the Toyota "sightline" beam blades that are designed as a service-replacement for cars that no longer have the factory blades. The Sightline blades are not refillable.
