The Fe is certainly lower than UAs, but the Cu is a bit higher.
I don't know enough about this tranny to say if there is an issue developing or not.
To understand the wear rates, it would be important to know the average miles of the UAs.
Does this system have an oil cooler that has Cu tubing or element brazing? If so, that would be a possible source of the Cu ppm. Not unlike when some syns are used in a Dmax engine; Cu will shed with certain lubes due to amines present until the system "normalizes" to the new chemistry.
I am not saying this is the case here; just offering a possible explanation.
i am not saying the Cu is a problem; just something to watch and make sure it does not escalate as a warning item with each successive UOA.
Everything else is well in control.
