Originally Posted By: ZeeOSix
Originally Posted By: Shannow
Originally Posted By: Ohle_Manezzini
No, it isn't!
So, going up hill (just 20% or 18 degrees) aclive, at 3k rpms for half an hour, the oil will be cooler than revving at 4k rpms in neutral for half an hour
Going up the same hill, with the same load, and same speed (total reactive effort if you will), the guy doing it at 3,000 RPM will have a lower oil temperature than the guy doing it at 4,000 RPM...we've been over it a couple (dozen ???) times with my measurements with a type k thermocouple down the dipstick tube.
Your thermocouple tests were on flat land at minimum engine load at different RPM ... not comparing minimum flat land engine load at say 60 MPH to much higher engine load going up a steep grade (or pulling a heavy trailer) for instance in the same gear (even if slightly lower RPM, but much higher throttle opening) to significantly increase the engine's load. Go try that actual test and come back with results. I think that's what he's getting at.
Yes, the truth ^^ Retest ^^
Hah, now the discussion turn to "same load", before was "regardless of load".
The worst story was that one were the ATF was going way up temperature, by reducing speed in lower gear going downhill, so you should use brakes or the fluid would overheat :headscratch: . Even worst was the problem of his wife killing the engine in the garage with the clutch could made a huge scar in the cranck journals. :headscratch2: Let's put up some pearls...
So, I endedup banned a few time because I spok what?
