I have not given up yet I am actually getting more and more determined to get this crazy thing back on my truck. I remember many years ago there was a oil filler cap that went on the valve cover that was drilled and tapped for 1/8inch pipe. 77 Chevrolet 350 engine stock valve covers. oil filler cap has the two little tabs stick out. covers stamped with two recesses, it goes in and turns a quarter of a turn and it's locked the oil is dumped right in there. anybody ever seen those lately? I called Frantz, they are not familiar with the older version but they're going to dig around and see if they have any,,,, if they ever did. It's either that or I'm just going to pull the stupid intake manifold and drill and tap up front and shoot it right into the valley, but standing on a rotten dissolving knee is a little painful I'm just trying to avoid that. There is also the possibility of just buying one it Checker,, drilling out the rivet that holds it all together and then putting in some kind of a bulkhead fitting , that would work too I guess. Sorry for a long post, just trying to make it is understandable as possible.
Mark
