Nope. If you are going to bother taking it off at all then replace it.
Even starting with a clean engine your engine creates its own gunk, and you dont really know the rate of "gunk production" and even if you do its not going to be completely consistent and as an engine ages - gets worse.
In my 3MZfe at 15K the filter dome has visible gunk in it that the pleats didnt absorb and hold that floated back into suspension.
The filter only holds XX amount of dirt, and even if the media stays viable and the filter intact for 21 you aren't able to tell how plugged the filter is or how often you get a bypass scenario which depending on the filter orientation could cause that very same gunk to get sucked right into the engine.
Unless its a gross producer you can't tell by looking at pleats or has visible carbon or sludge chunks in it.
Net net - I just replace it at the interval on the box and dont risk my engine on stretching out a 8 dollar filter.
...as always thats merely my own opinion.
UD
UD
