So if you have a high HT/HS rated oil, like some of the EURO oils that list HT/HS rates at 3.5-3.7, does that mean that the oil boundary layer will be maintained at a higher rpm range on crankshaft, rod, cam bearings, etc? Would the EURO spec oils boundary layer be greater (thicker)than with an oil rated with a 2.0-3.0 HT/HS rate if both were subject to the same rpm / temperature rate? I find it hard to believe that a lot of the European manufactured engines for the European market would have engine tolerances / operating speeds / operating temps, that vary that much from the Engines manufactured in the USA for the USA market, thus requiring the higher HT/HS spec oils for them (EURO built engines for the Euro market) versus the lower HT/HS oils spec's for our vehicles. Or, does the oil spec's we see recommended in our owners manuals just just relate to CAFE requirements?
