So, I was in the process of trying to fix the remote audio controls on the '02 Accord which is fairly straightforward per TSB 03-022 (I believe that was the #). So, certainly a first world problem. However, in using the steering wheel puller, one of the threaded aluminum holes in the steering wheel stripped - threads pulled clean out. So, what now? I don't like to leave something broken for several reasons, but the first is that I can hopefully learn another fix. I don't like to punt problems down the road when the steering wheel really does need to be pulled. Thank you.
