05 BMW 325i QS-PZ mix 5W 40 (10,636 miles)
Grand Rapids, Michigan
80% City 20% Highway Driving
Oil Capacity 6.9 quarts
Code:
Date 01/17 12/15
Oil 5W 40 QS-PZ QS
Oil Filter MANN MANN
Unit Mileage 41748 31112
UOA Mileage 10636 4491
UOA Days 391 303
Make Up Oil None None
Metals
Iron 20 7
Chromium
Lead 2
Copper 23 8
Tin
Aluminum 9 6
Nickel
Silver
Titanium
Vanadium
Contaminants
Silicon 5 3
Sodium 3 9
Potassium 6 8
Additives
Magnesium 15 13
Calcium 2490 2408
Barium
Phosphorus 789 837
Zinc 1121 1014
Molybdenum 51 50
Boron 43 41
Contaminants
Water
Coolant No No
Physical Tests
Viscosity 12.6 11.1
Base Number 2.3 3.4
Thanks TOTO.
Looks good, IMO.
I stopped doing UOAs on mine. I now just change it once a year.
Yeah I know I could get by with no UOA eventually but it's my hobby, I have friends and co workers that spend hundreds if not thousands of dollars on hunting, fishing, guns and football so I figure I can afford $13.99 plus $3.00 for postage a few times a year, plus I'm going to get back to buying my WIX products online and the UOA kits are $9.98.
Thanks TOTO.
Totally understand.
That was the last year they used the M54 engine in there, with iron cylinder liners.
At first I thought that was a lot of iron for an N52, which has no iron liners, and the engine used after the M54.
So its OK to mix oil brands? At least those are both Shell oils.
Didn't know that about the engine thanks for the information, as for mixing oil it was refilled with a 50/50 mix of 5W40 PZ & 0W 40 Mobil 1 as it is being switched over to M1 for one reason I can get 5 quart jugs for $15.99 each so we will see what next year's UOA looks like!
Thanks TOTO.
Mobil1 and Pennzoil both get their additive packages from Infinitum (jointly owned by the two companies) so maybe they perform well when mixed. Only 'maybe'.
There could be a dependency on %Ester vs. %GroupIII vs. %PAO vs. additive chemistry vs. seal swell ....etc.
Mixing ruins the engineer's goals, yet it might be just fine AFAIK. No worries. We all do it.
