Originally Posted By: veryHeavy
EXECUTIVE SUMMARY
The gunk is Base additive to boost TBN as high as possible.
Quote:
The response from pennzoil
Hibnello:
Finding sediment or deposits at the bottom of new bottles of motor oil is a common and harmless occurrence in all conventional and synthetic motor oil products in the market today. This may occur regardless of the base oil used and does not negatively impact the performance of a motor oil.
Most often, the sediment found is a by-product of a type of nanotechnology used in motor oils to keep the pH balance correct in storage, and then in use inside a motor. The practice is commonly referred to as over-basing a motor oil and is designed to account for the acids formed in an engine during the combustion process.
Periodically, some cosmetic dropout from motor oil is observed in a bottle, and that is most typically due to the result of effective nanotechnology in action, or the slow release of over-based detergents to help neutralize acids. Motor oil formulations are highly specified to help reduce the incidence, but ultimately over time some harmless molecular dropout will occur.
The filtration process employed when formulating the motor oils removes much of the sediment, and then once in use in an engine, any remaining particles are removed through normal operation.
Regards,
Well slap me silly, nanotechnology, who knew! Me thinks those little disgruntled nanites are planning a revolution.
