silverrat Joined Jan 9, 2009 Messages 1,798 Jan 14, 2017 #1 Can anyone help identify what this noise is? It has happened twice in the last 7 days immediately after a cold start below freezing temperatures. It goes away after 20-30 seconds. My apologies for the camera orientation. Last edited: Jan 14, 2017
spasm3 Joined May 30, 2010 Messages 16,780 Location North Carolina Jan 14, 2017 #2 Sounds like bad bearings in either the belt idler pulley or tension arm. Listen around the alternator in case its that. P.S. I think i remember hearing a bad a/c clutch making this noise as well. You need a mehanics stethoscope. Look at everything spinning at night with flashlight, look for any wobble in the pulleys. Last edited: Jan 14, 2017
Warstud Joined Sep 2, 2005 Messages 10,446 Location MIchigan Jan 14, 2017 #3 I'm going to say it's coming from your a/c clutch. But it could be any one of the belt driven components.
mclasser Joined Apr 13, 2013 Messages 3,221 Jan 14, 2017 #4 Take off the belt and give all the pullies a spin and tug.
silverrat Thread starter Joined Jan 9, 2009 Messages 1,798 Jan 21, 2017 #5 Thanks guys, it was the AC compressor.
