This came off of a 1996 Mazda MPV. A friends father was in town and they only drive this when they're in town. Most of the time it sits in storage. I had replaced the starter for them two days prior to changing the oil. Forgot to take a picture of inside the can but it was relatively clean.
If you notice, the spring is wrong. If you look at the Toyota filter, that is the correct spring.
Refilled with 5 qts of Valvoline SynPower 10W-30 that Amazon sent me incorrectly that ended up costing me ~$22 for a case of 6 qts. They supplied the filter. Same type of filter went back on.
