demarpaint
Thread starter
Originally Posted By: The_Nuke
Ignore the Intel Microcode thing, you can run it with that activated or without, won't make a difference for your freezing problem.
IMHO, the video driver is a good candidate, but you should be able to run different versions of it to test that theory. Swapping out the video card may work, but only if the different hardware requires a different video driver that isn't susceptible to the freezing problem's root cause.
I have an old PC clone with an Intel Mobo, Pentium CPU, DDR2 mem, etc. that sounds like it's very close to the type and architecture of hardware you are running, and I have three different versions of Mint installed on it (17.3 Cinnamon, 18 Cinnamon, and 18.1 MATE). So far, it has frozen up on me just like you describe (manipulating text in a LibreOffice Word document) on two of those and required a hard reset to resolve each time.
I haven't seen the freeze on the 18.1 yet, but it is running a different version of the nVidia drivers which I believe are causing my problems in the other two. Also, once I backed out the nVidia driver in the 17.3 and started using the generic version that is available for nVidia cards, I haven't seen anymore issues (but also stopped messing with LibreOffice for time being).
One other method by which I was able to test the various drivers' compatibility with its target setup was with the installed browsers (Vivaldi, Firefox, etc.) or any software that allows disabling/enabling of hardware acceleration (using the GPU). If the driver was giving me problems, it was always evident in how the programs that used the hardware acceleration behaved, and once I turned it off in those programs, they stopped acting up (blinking screens, etc.).
It may ultimately end up being a combination of things like the kernel version, desktop flavor, software bug, and video driver. Or maybe it's just 2 of the 4, or even 3 of the 4...and removing one of the elements of the equation will prevent the crashing even though the other elements remain.
Either way, the video drivers are going to be involved somehow I am willing to bet. Keep notes on what you're running now, what you run with new video card, and any other changes to them in future. If you get another freeze, write that down next to the driver notes. It may take a while, but you can probably narrow things down to what just doesn't play well together and avoid them altogether in an attempt to stop the crashing.
One more idea: stop using Libre Office in the interim (except for when trying to recreate or test new drivers/hardware). Use Google Docs or even Microsoft's free versions of Word/Excel/etc. to do your Office related tasks instead. They are all online (not installed locally per se), but they all have installable apps which can be installed in the browser you use (Chromium & Vivaldi at the very least) to make it more like you're using software installed locally on the PC.
Not exactly like the experience of having the suite on your PC, but close enough and good enough to get you by while you figure out what needs to be done to stop the crashes.
Thanks for the info. One thing that did help a little was disabling the hardware acceleration, I did that a few days ago. Yesterday I got through the day w/o a freeze, but I didn't do anything graphic intensive. This machine is an entry level business machine, which was given to me to fool around with, I enjoy working with computers. The graphics card is integrated with the chipset, and I believe that is where my problem lies. Point taken about using Office, however it has frozen simply moving from a website to the desktop, or loading a picture or video on a website. But if I push it hard with copying and pasting pictures into a document I can get the problem to happen. I will try one of the online office programs and see what happens if I have some time today. I never gave that any thought.
Another thing I noticed, if I hover over the show desktop icon while reading something in either Firefox, or Chromium it switches over to the desktop, and sometimes freezes things up. If I click on the show desktop icon the odds of it happening are a lot less, if that makes sense.
I have taken notes, and I will resolve this issue, sooner or later.
Thanks again for the good info! I got more info here than on the Linux board.
