Originally Posted By: supton
Originally Posted By: Wolf359
Originally Posted By: Bluestream
Originally Posted By: djb
With E10 gas in most of the U.S., there isn't much of an issue with "water in the tank". Yes, there is some water there. It came in with the alcohol, and will go out with the alcohol. You could add a liter or two of water with every tank fill and not have a problem.
Search "phase separation" Your comments are just not true. Pour 2L H2o in every tank? Umm no
Yeah, a gallon of E10 can handle up to 3.8 teaspoons of water before phase separation, less at lower temperatures. So a 20 gallon tank can handle up to about 12 ounces of water. To hit a liter, your tank would be over 50 gallons and 2 liters would be over 100 gallons. Not too many people with a gas tank that big.
Good info, thanks. Seems like a large amount of water. Dumb question: back before E10, what happened? Didn't water just build in the bottom of the fuel tank, until it reached the pickup level?
You bought bottles of dry gas which was basically alcohol. Or you kept your tank full. You would get condensation and water in the tank if it wasn't full. It was never really a big problem, more so if the car sat for long periods.
