Originally Posted By: TudBlana
opinions about Polytron oils
My opinion?
I will NEVER spend that much money on an oil the makes such OUTLANDISH claims!
ALL oils "may increase engine life", LOL!!
https://www.amazon.com/Polytron-Synthetic-15W-40-Motor-Gallon/dp/B00BYF0RYE
For use in automotive, marine, heavy-duty engines (gas, diesel, marine, 2-stroke), compressor pumps, and other suitable equipment. Can be used in older engines, as well as modern engines. DIRECTION: Directly replace the motor oil during oil change with specific viscosity rating (i.e. 5W-40); Polytron MTC added in.
• Polytron Full Synthetic Motor Oil is made of premium synthetic oil with a standard additive package, while adding Polytron proprietary complementary additive, Metal Treatment Concentrate (MTC). Scientific breakthrough, Polytron MTC treats the metal surfaces, not oil; reduces friction significantly. Polytron does not contain any solid particles (i.e. PTFE, Zinc, etc) and is not viscosity modifier. Originally developed for military/government applications
• Eliminates engine wear up to 95%;
may increase engine life span by 200-300%; engine may be protected in the event of oil or coolant loss by adding 10% by volume; maintenance cost savings often exceeds 60%
• Contributes to cleaner emissions, reduced engine/equipment operating temperature, improved performance – power, torque, fuel (mpg) and oil economy
• Keeps engine totally clean of any deposit build-up and
may considerably extend oil change intervals 300-700%; protection against extreme temperatures, dirt, and moisture
