229.51
by RogerBacon
02/22/18 06:25 AM
One way to get the rust off under your vehicle...
by rollinpete
02/22/18 04:04 AM
Loud hum noise from front brakes
by Jimmy9190
02/21/18 10:47 PM
Rat: Trap or Poison
by WhyMe
02/21/18 10:27 PM
STIHL Hp ultra fail??? Or my fault???
by Matt2stroke
02/21/18 09:42 PM
Wrestling pretzel hold. Ouch!
by callbay
02/21/18 09:41 PM
Serpentine Belt noise
by Tdbo
02/21/18 09:31 PM
Coolant Leak
by Ducked
02/21/18 09:13 PM
Does lots of starts let gas get in oil?
by tc1446
02/21/18 08:44 PM
Avalanche front and rear diff change.
by spasm3
02/21/18 08:40 PM
Abuse proof rental home flooring
by Oldtom
02/21/18 08:17 PM
Low Noise Oil
by Ducked
02/21/18 07:55 PM
2017 Dodge charger review
by gabriel9766
02/21/18 07:51 PM
Dry reusable air filters?
by WillB
02/21/18 07:42 PM
Batteries @ Menards
by Tdbo
02/21/18 07:29 PM
Blotter Spot Test
by Emanuel
02/21/18 07:22 PM
Is arming teachers the answer?
by ZZman
02/21/18 06:45 PM
Another ATF question... I aplogize
by bardos
02/21/18 06:12 PM
To Seafoam or Not?
by Marco620
02/21/18 06:07 PM
2017 Ford ecoBoost 1.5 Oil Filter Top View
by tenderloin
02/21/18 05:50 PM
WiseOne, ryan6548, pjmbull, 92zx, Ara
64253 Registered Users
52 registered (Armkb, 2015_PSD, 4WD, B767capt, alarmguy, 4 invisible), 1072 Guests and 100 Spiders online.
64253 Members
65 Forums
278522 Topics
#4094742 - 05/12/16 09:21 AM Kubota L3200 oil change intervals
Canadastang Offline
Loc: Ontario Canada
I have a Kubota L3200 - 3cyl diesel, running Mobil Delvac 1300 15W40.
The tractor has about 160 hours on it and I change the oil yearly.
In reality, I only rack up about 30 hours per year, if that.
It's never short tripped, and is always run to max pto-rpm when in use, with very little idling time. It's stored indoors, so the coldest start would be from about 40*F.
My service manual states to change the oil and filter every 150 hours, but nothing about intervals based on time, so I just change it yearly.
Am I wasting my time and money doing this, could I stretch the intervals to 2 or 3 years, or is that a bad idea?
#4094745 - 05/12/16 09:25 AM Re: Kubota L3200 oil change intervals [Re: Canadastang]
Bgallagher Offline
Loc: Boston, MA
I would change it yearly anyways or do an UOA to see. Frankly I look at yearly oil changes as cheap insurance.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
#4094783 - 05/12/16 10:31 AM Re: Kubota L3200 oil change intervals [Re: Canadastang]
IndyIan Offline
Loc: Ontario, Canada
It sounds like you get the oil nice and hot when you use the tractor, but waiting 5 years could be a bit long. I imagine if it mattered much Kubota would give a time interval as well, as they know many get usage like yours.
If you like 2-3 years then I'd do that. My longest time between changes on my tractor would be around 2 years and the motor looks like new inside. I just follow the hourly intervals.
07 Focus ZXW, 5spd manual, 190km VWB 5W30
06 CRV, 5 spd auto AWD, 306km M1 EP 5W30
#4095622 - 05/13/16 09:42 AM Re: Kubota L3200 oil change intervals [Re: IndyIan]
Canadastang Offline
Loc: Ontario Canada
I guess I misread the manual, it actually calls for 200 hour changes, with no time limit.
No way would I go 6.5 years on the same oil, but I'm thinking 1 year may be excessive, considering it's always brought to operating temp.
Slightly off topic, but my grandfather went 25 years on one oci on his tractor....not that I'd recommend that.
Shockingly, the engine only has a little bit of sludge on the valve covers.
The filter was, well, it looked like a grease trap.
It's still running strong to this day lol.
#4095624 - 05/13/16 09:51 AM Re: Kubota L3200 oil change intervals [Re: Canadastang]
IndyIan Offline
These motors are pretty understressed, I was surprised how common it was for people never to change the trans fluid on a tractor. I guess the interval is pretty long (800hrs) on most but still that doesn't mean never... Mine has a hydrostat trans so I'm sticking with 400 hrs or less as its the last one I want to buy.
#4095649 - 05/13/16 10:33 AM Re: Kubota L3200 oil change intervals [Re: IndyIan]
Canadastang Offline
Loc: Ontario Canada
HST trans here too. 400 hours is listed in my manual for fluid changes.
They're filled from the factory with SUDT, but dealers in Canada only carry Kubota UDT, which I've noticed causes slower pedal reactions in cold weather and more whine. Aside from buying SUDT in the states and bringing it over, I haven't found any viable alternatives. Yet.
Any suggestions for trans fluid in Canada?
#4095983 - 05/13/16 04:21 PM Re: Kubota L3200 oil change intervals [Re: Canadastang]
CT8 Offline
Loc: Idaho
I have a John Deere 4310 and I change the oil and filter once a year be it 30 hours or 100 hours. The trans and hydraulic,common sump are every 400 hours with filters changed every 200 hour. John Deere has a low vis tractor hydraulic oil and most oil jobbers probably have an oil that will be rated to work for your tractors specs. The Kubota and John Deere specs are the same !!!
#4098852 - 05/17/16 07:49 AM Re: Kubota L3200 oil change intervals [Re: Canadastang]
IndyIan Offline
Petro canada has a syn trans lube that has impressive specs. Its a bit expensive of course. I was surprised how thin SUDT is a 100C, and its not what I'd put in anyways, but lots of people seem to do well with it.
I'm going with the regular petro can duratran as it seems to still have better cold start performance than any other regular fluid but still keeps its viscosity at 100C. The syn stuff does shear down abit with some use.
You might be able to just use the duratran XL which is PC's winter fluid as I think it matches SUDT for 100C viscosity anyways.
PC seems to be the only company that really publishes a full set of specs and test results. http://lubricants.petro-canada.ca/en/products/567.aspx
I often seem to be using my tractor to move dirt, so I'm more worried about how the fluid does at full temp under load.
#4099419 - 05/17/16 05:56 PM Re: Kubota L3200 oil change intervals [Re: Canadastang]
CT8 Offline
Loc: Idaho
The fluid works the trans and hydraulics!
#4099911 - 05/18/16 08:11 AM Re: Kubota L3200 oil change intervals [Re: CT8]
IndyIan Offline
Yep, neither really likes thin fluid at high operating temperatures.
I was reading in some construction eqp magazines that is often well worth the money to buy hyd fluid with very high VI to keep heavy equipment operating efficiently through out the day.
#4100399 - 05/18/16 06:58 PM Re: Kubota L3200 oil change intervals [Re: Canadastang]
dlundblad Offline
Loc: Midwest
I go every other year with the L4330 and 5w40 M1 TDT. Ill have to check the OM on the HST fluid.
03 Jeep WJ 4.0 197k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 170k M1 0w40 Mann HU818X
97 Chevy Blazer 4.3 138k Synpower 5w30 Fram TG3980
#4100649 - 05/19/16 05:11 AM Re: Kubota L3200 oil change intervals [Re: Canadastang]
tc1446 Online   content
Loc: Lexington, NC
Once a year, often less than 50hrs on my Kioti 30hp diesel with Hydrostatic drive.
Hydralics not changed yet but coming up on 400hrs shortly; I'm unable to do it so have to have it hauled to dealer which is
costly!
'13 Accord EX-L 2.4L (80K) M1 & FU
'00 Ford Ranger 4.0L {65K} M1 & FU
'18 Vanderhall Venice 1.4 Turbo(1.5K) CastrolEdge/Delco
'07 Kioti CK-30
#4305544 - 01/17/17 08:52 PM Re: Kubota L3200 oil change intervals [Re: tc1446]
earthmover1980 Offline
Loc: SW Michigan
I would change the engine oil annually or 200 hrs, whichever comes first. That is my policy for our entire fleet. A 250 hour oil change interval is typical for heavy equipment. Seeing that your Kubota Engine only holds around a gallon and uses a small filter, current oil changes and maintenance are cheap insurance.
