Hello, I just bought a 2005 Ram Quad cab 4x4 with a 4.7L engine. After reading about the engine and a poor design the engine collects moisture in the oil fill tube. My truck has Dodges hide the problem fix in the fill tube. However, I have noticed it is starting to get some of the sludge in the fill tube. The engine has 60,000 miles on it. Here are my questions and ideas.
1. Has anyone come up with a fix that works?
2. Here are some ideas I have.
a. Switching to Valvoline synthetic oil
b. Wrapping the fill tube which is plastic with a heat tape to keep the temp up and help burn off moisture.
c. Drilling a hole in the oil fill cap and then fixing a plastic tube which will allow the moisture to escape the fill tube if the synthetic does not fix the problems.
Any fixes that some one has used on this engine that worked would be appreciated. Any ideas on the proposed fixes I have suggested.
Thank You,
Art Thompson
Thank You,
Art Thompson
