Guys:
Have a good one for you, Problem: Car running fine, pull into garage and car makes a loud whistling noise. Also, RPM increases to 1500 at idle (normally 500). Note: whistle will go away and then RPM will increase and whistle start again. Idle also seemed rough.
Restarted the car and whistle is gone. Drove car last couple of days and no whistle. Called BMW and they said may be VANOS (think that is variable valve system) system malfunction. They say they could look at it but suggest I drive it until it gets worse. Also say it unlikely that a maintenance code was recorded.
Guess I will drive it and see what happens but am uneasy about reliability.
Any thoughts from you guys? Suggestions welcome.
JR
JR
