I didn't like the way he went after the cam seals with those tools without protecting the shaft first, you can either drill 2 small holes with an angle drill in the metal part of the seal and use 2 sheet metal screws to pull/wiggle the seal out or cut a piece of plastic water jug to slip in between the shaft and seal so the tool doesn't touch the shaft.
Messing around with metal tools on the shaft is bad practice, always inspect the shaft surface for nicks or wear groove where the seal contacts the shaft and use a repair sleeve if necessary. Do not use oil around the outside of the seal, this is where they leak many times and using oil just makes it leak easier.
The reason for this is the different expansion rates of the aluminum head and the metal seal shell, the seal expands less at operating temperature than the head causing the seal to become slightly loose in the bore.
Use a non drying sealer like Permatex high tack or Hylomar on the outside of the seal and make sure the bore is clean and dry with a little brake cleaner on a rag, this will prevent seal walking and leaks without making future removal difficult like RTV or shellac, it also acts as a short term lube to make installation easier, use engine oil on the rubber seal lip.
A little extra caution and proper installation of the seals goes a long way in making the repair long lasting and leak free
Use a torque wrench and cam holing tool on the cam and a pulley holding tool for the crank bolt which my also require an angle gauge for the crank check the FSM.
