Hi all:
I've never used car jacks since I never had a need to work under a car. But now with my 2015 Corolla, it sits so low to the ground I can't get under there to change the oil without using ramps. I want to have a set of car jacks for extra security but had a question. Of course I run the car up on the ramps first, but then do car jacks "crank" up to the desired height and you lock them in that position, or do they have a set of holes that you insert a pin at the highest point possible?
