Nick1994
$100 site donor 2024
This started happening 2-1/2 weeks ago. I've been thinking it's the transmission, but now I'm wondering if it's a sensor or something else.
When accelerating from a stop with lots of throttle, it stumbles, almost acts like the transmission is slipping, but the RPMs don't shoot up. If I take off gently, it's fine. Once the RPMs are above 2,500 or so, it's fine. Driving at 40 mph or 70 mph is perfect, even under heavy acceleration.
I've also noticed when slowing down to a red light and I reach around 20 mph if the light turns green and I give it 1/2 throttle or a little more, it does the stumbling. But if I give it full throttle at that speed, it downshifts to where the RPMs are nice and high and it's normal.
I've also noticed when sitting at a light that it will also have a "miss" for a split second occasionally. All of a sudden it's a bump of it cutting out, hard to explain.
It does this with a warm or cold engine. I have no CEL and no pending codes. I bought the car August 2015 and have since put on a little over 30,000 miles. When I bought it I put in new OEM spark plugs, new spark plug wires, new PCV valve, new air filter, and a new fuel filter.
Here's a link to a video I recorded. I was at about 3/4 throttle. You can hear the RPMs climbing weird in the beginning and if you watch the tach you can see it get a little stumbly before 2,500 or 2,700 RPMs. The creaking sound at the beginning is the rear strut mounts, they're on the to-do list.
