73 Corvette with unknown oil mileage report
by Hawkfanatic
02/21/18 08:51 AM
Water etching on autoglass
by CleverUserName
02/21/18 08:45 AM
It's still on new Fram website
by goodtimes
02/21/18 08:30 AM
Conventional question
by supton
02/21/18 08:27 AM
1998 Chevy 1500 engine replaced
by RF4guy
02/21/18 08:18 AM
Hyundai Accent Oil Filters
by RF4guy
02/21/18 08:06 AM
Does anyone remember Jay "Pee Wee" Gleason?
by grampi
02/21/18 08:04 AM
How would you use your gun?
by ZZman
02/21/18 07:59 AM
Windshield: sealing crack
by supton
02/21/18 07:49 AM
RIP Billy Graham 1918-2018
by Char Baby
02/21/18 07:36 AM
Grease for Telescopic/Tilt Screws Lexus LS430?
by Gebo
02/21/18 07:34 AM
Redline Break-in Additive on rebuild engine ?
by taoybb
02/21/18 07:30 AM
Battery, 09 Acadia
by Old Mustang Guy
02/21/18 07:23 AM
Random P0455 gross evap leak/no flow code
by Dave Sherman
02/21/18 07:11 AM
For Sale: Matco Torque Wrench
by mobilaltima
02/21/18 05:19 AM
Federal Personal Defense
by BlueOvalFitter
02/21/18 03:15 AM
Mixing TGMO 0w20 and Castrol Euro 0w40!
by FranklinJL
02/21/18 02:27 AM
Why is "7.5" scoffed at, but 16, 8, and 4 are OK?
by gfh77665
02/20/18 11:56 PM
F-350 Batteries - What Not To Do
by tom slick
02/20/18 11:05 PM
Expert Installatiion Charge
by ZeeOSix
02/20/18 10:06 PM
TallerTrucker, GTIguy5, AaronD81, RF4guy, jt5851
64245 Registered Users
92 registered (ajbranz, ARCOgraphite, 2009Edge, Alfred_B, 2001SE, 2K2AcuraTL, 6 invisible), 1500 Guests and 93 Spiders online.
64245 Members
65 Forums
278479 Topics
Page 2 of 2 < 1 2
#4302119 - 01/14/17 12:00 PM Re: Used and abused, your input is appreciated [Re: dnewton3]
kschachn Online   content
Loc: Upper Midwest
Originally Posted By: dnewton3
The condemnation limit is any characteristic measured that has an established magnitude limit. In this case I was referring to the iron count.
I did, however, make a mistake; I thought that the DD FE limit was 100ppm.
Using this guide:
http://www.calrecycle.ca.gov/Publications/Documents/UsedOil%5C2008020.pdf (page 16)
I see that it was Cummins that has a 100ppm limit, whereas DD has a 150ppm limit for Fe.
Right I get that. But it's for the engine, not the oil.
1994 BMW 530i, 224K
1996 Honda Accord, 251K
1999 Toyota Sienna, 387K
2000 Toyota ECHO, 264K
#4302405 - 01/14/17 05:04 PM Re: Used and abused, your input is appreciated [Re: dustyroads]
NStuart Offline
Loc: Sav ga
100c was 16.73
Originally Posted By: dustyroads
NStuart, could you list the viscosity at 100C (KV100) to complete the info.
I've never run a truck locally, so I can't offer you much. I would only advise you to pick a lab and stick with it. You should use one that provides soot %, as that is a concern and another condemnation point. There are plenty of good labs, but a good lab with very reasonable cost is ALS Tribology. You can get NAPA labeled kits from any NAPA dealer, and they go to ALS in Atlanta. Last I knew, their kits were about $14.00 or so.
I would try to pick an oil based on accessibility and overall cost. Overall cost being a combination of purchase price and the longevity you think can be achieved with it. Don't overlook the basic 15W40 oils, especially when using a good bypass filter. They are far better and longer lasting (TBN) than given credit for. I used to get Castrol Hypuron synblend (now called Vecton) at Fleetpride (a national truck parts distributor) for a very reasonable price. That oil had amazing TBN retention. The new CK-4 oils in general, are made to maintain good oil properties for longer intervals than previous generations.
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
#4302426 - 01/14/17 05:16 PM Re: Used and abused, your input is appreciated [Re: NStuart]
NStuart Offline
Loc: Sav ga
I just spun on new filters when I sent the samples out and added 1.75 gallons to top off. Am I correct in saying that the added (or removed) oil will slightly lower the wear metals? I'm going to run it another 0-5k miles and change it while sending another sample. 5K is 5 weeks, this will allow me to put a bypass kit together and get good oil ready to go. I guess you could say this truck in the second sample is part of a family partnership and I was given the go ahead of upgraded filters, bypass, and "botique oil"
And yes 150 ppm fe and 30 pm pb is Detroit's condemnation numbers
#4304009 - 01/16/17 10:34 AM Re: Used and abused, your input is appreciated [Re: NStuart]
NStuart Offline
Loc: Sav ga
Any thoughts on added oil reducing wear metal numbers?
#4304013 - 01/16/17 10:36 AM Re: Used and abused, your input is appreciated [Re: NStuart]
Loc: Upper Midwest
Yes, it dilutes the concentration. How much depends on the quantity (percentage) of make-up oil that is added, and when it was added during the interval.
1994 BMW 530i, 224K
#4304153 - 01/16/17 12:51 PM Re: Used and abused, your input is appreciated [Re: kschachn]
NStuart Offline
Loc: Sav ga
thank you .the amount of makeup oil was between 15 and 20% sump capacity.
#4316164 - 01/29/17 07:05 PM Re: Used and abused, your input is appreciated [Re: NStuart]
NStuart Offline
Loc: Sav ga
Just a little update I finally put together and installed amsoil bmk30 kits on both trucks, I bought my own lines and fittings, all steel parker #8 jic fittings and 300* 4300 psi tough guard hose. Fumoto drain valves and 2 dbl3998 donaldson synthetic long life filters and went with schaeffer 9000 5w-40 synthetic.
this was the first weekend of had free in a while so I went ahead and changed the oil in both trucks. I took samples to send to blackstone, the million mile truck with mystik oil was at 16k on the oil sample. The 200k mile truck had 42k on rotella t6 at the time of the sample. I am mailing them out tomorrow .
I am not going to send samples out again until the 20k miles on the Schaeffers unless I feel there is an injector issue or other reason for concern.
The truck with 1m miles The oil oil is usually pretty black immediately. When I finished the install the driver went on a 400 mile run , I checked the oil when he got back and it was still clear. I wonder With Schaeffers detergent on a million mile engine how long the oil Will stay clear . if the 20k samples come back good I will change the ff's at 30k and sample again
One interesting note the bypass added 1.25 gallons of oil, my laser temp gun showed a 20* difference between the oil in And oil out of the filter. I will Check oil pan temps tomorrow when I get the 200k mile truck up to operating temp in 70* weather, before install and oil change I was seeing 190 at the oil return and 202* at the filters.
#4323144 - 02/07/17 08:27 AM Re: Used and abused, your input is appreciated [Re: NStuart]
NStuart Offline
Loc: Sav ga
Just another quick update on still waiting on samples to come back , should get them in the next three days. The truck with 200,000 miles on it is running 24 hours a day since last Monday. Prior to schaeffer oil change the fuel mileage on 3000 gallons was 5.7 mpg. Since the Schaeffer Oil Change and the bypass install the truck has used 450 gallons of fuel and the current fuel mileage is 6.22 MPG . The air filter and fuel filter we're not changed the truck is running the exact same route pulling the exact same load. The truck is running 24 hours a day because the million-mile truck hit a deer last week so the whole front of the truck has to be replaced. The one good thing about it running 24 hours a day is I will sample more bc of the quicker mileage put on the truck. Just a quick side note there really is no idle time with what we do
#4323787 - 02/07/17 09:40 PM Re: Used and abused, your input is appreciated [Re: kschachn]
Rob_Roy Offline
Loc: Northern, NY
Using this guide:
Those are the levels at which the oil is not considered serviceable any longer. If you want to maximize you drain intervals, you run the lube until the levels of wear metals (or soot, fuel, etc) have come close to or reached the limit suggested by the manufacture.
Since you have decided to try Schaeffer products, I highly recommend you try their UOA service. They will guide you on extending the drain intervals.
2016 Ford Expedition 3.5 Ecoboost
2015 Subaru Legacy 3.6
2014 Subaru Outback 2.5
1999 Ford F350, V10
#4326484 - 02/11/17 09:11 AM Re: Used and abused, your input is appreciated [Re: NStuart]
NStuart Offline
Loc: Sav ga
Edited by NStuart (02/11/17 09:16 AM)
#4326492 - 02/11/17 09:27 AM Re: Used and abused, your input is appreciated [Re: Rob_Roy]
Loc: Upper Midwest
Then in dnewton3's example they are using the iron level of 100ppm as a proxy for the condition of the oil, as iron would not be a contaminate.
1994 BMW 530i, 224K
#4326494 - 02/11/17 09:30 AM Re: Used and abused, your input is appreciated [Re: NStuart]
NStuart Offline
Loc: Sav ga
That is the last sample from the 1m mile truck it was taken as I was install ing the bypass, 16k on mystik (ignore the 6k sample that is for my a tax write off lol)
Stand by for the 200k mile sample
#4326498 - 02/11/17 09:38 AM Re: Used and abused, your input is appreciated [Re: NStuart]
NStuart Offline
Loc: Sav ga
200K mile 40k on t6 3 filter swaps 19k,31k,37k changed at 40k and bypass installed http://s347.photobucket.com/user/Ramncum...?sort=3&o=0
#4326508 - 02/11/17 09:49 AM Re: Used and abused, your input is appreciated [Re: NStuart]
NStuart Offline
Loc: Sav ga
Page 2 of 2 < 1 2
