What the title says. I've heard you pour depending on how sludged up the engine is due to its potency. So if your engine is bad just start with mixing half a quart to a quart in max. And from there you can do different types of mixes later down the line. Like 50% kerosene, 50% oil. Let the car idle anywhere between 10-20 min. Then drain and fill with new oil and filter.
General census of the 'old heads' (ages 60's-70's) I've talked to tend to go by using this stuff. That all these new motor flushes on store shelves are [censored] and marketing schemes.
What's your opinion on using kerosene or diesel fuel for an engine flush?
