02 Censors?
by lawnguy
04/20/18 08:06 PM
Canadian Rebates for Rotella T-5 and T-6
by Snagglefoot
04/20/18 07:58 PM
Car buying and lessons learned
by madRiver
04/20/18 07:52 PM
Check out my tree
by Chris142
04/20/18 07:52 PM
New Starter Test Report Says Solenoid Fail
by chevys10
04/20/18 07:43 PM
Fram Tough Guard Air filters for Canadians
by Snagglefoot
04/20/18 06:40 PM
Recommendations for a Repossed Vehicle
by Astro_Guy
04/20/18 06:36 PM
Added Bluetooth Audio Streaming
by The Critic
04/20/18 05:27 PM
Lowest NOACK Synthetic 5W30 for Non - Turbo GDI ?
by ChrisD46
04/20/18 04:57 PM
Dad commited suicide yesterday
by motor_oil_madman
04/20/18 03:56 PM
What tool is needed to remove a hub bolt?
by llmercll
04/20/18 03:55 PM
1998 Nissan Frontier chatter/driveline issues...
by MGPD03
04/20/18 03:45 PM
2018 Chevy Equinox 1.5T mini-review
by road_rascal
04/20/18 03:21 PM
Aftermarket belts Infiniti G35
by mb32
04/20/18 02:58 PM
Mixing, example: Valvoline syn pre and post d1G2
by wemay
04/20/18 02:56 PM
Magnatec lovers
by Dyusik
04/20/18 02:42 PM
Best detergent oil for light sludge in Toyota 3.4
by DPRespecki
04/20/18 02:15 PM
Any of your mowers have PCV systems/valves?
by SOHCman
04/20/18 02:02 PM
Do you like woodgrain interior trim in Vehicles?
by ZZman
04/20/18 01:08 PM
Insane or Sane: small oil circulating pump for gen
by henni
04/20/18 01:06 PM
brillo54, SirEatsALot, Alko, Projecto, Kole
64792 Registered Users
92 registered (2009Edge, aquariuscsm, 2015_PSD, 4WD, 01rangerxl, bdcardinal, 8 invisible), 1546 Guests and 47 Spiders online.
64792 Members
68 Forums
282034 Topics
Page 1 of 2 1 2 >
#4299714 - 01/11/17 02:50 PM Danger Levels of ZDDP?
-SyN- Offline
Loc: Tornado Alley
Within today's modern catalytic converters what are the limits of ZDDP within today's oils that will over time damage the function of converters themselves?
17 Ram 2500 6.7L CTD- >Rotella T6 5W-40
14 GMC Sierra 5.3L-->PP (HM) 10W-30
12 Ford Edge-X2 Limited & SE->PP (HM) 10W-30
#4299720 - 01/11/17 02:54 PM Re: Danger Levels of ZDDP? [Re: -SyN-]
09_GXP Offline
Loc: Indianapolis, IN
Not sure what you are asking for here. The systems today are designed to survive the limits of additives that are in modern oils. They are not tested against older specs so their survival cannot be guaranteed. If you use an oil that meets the recommendations of your owners manual then the aftertreatment system will be fine.
2017 Miata Global Cup Car #02 - Castol A3/B4 5w30 w/ OEM Fitler
2017 Miata RF - PP 0w20 w/ M1 Filter
2015 F-150 2.7L Ecoboost - PPPP 5w30 w/ MC
#4299723 - 01/11/17 02:56 PM Re: Danger Levels of ZDDP? [Re: -SyN-]
-SyN- Offline
Loc: Tornado Alley
What levels of Zinc/Phosphorus (PPM) are dangerous to today's cats?
#4299730 - 01/11/17 03:04 PM Re: Danger Levels of ZDDP? [Re: -SyN-]
Miller88 Offline
Loc: Onondaga County
I don't think it matters unless you're burning significant amount of oil
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
#4299731 - 01/11/17 03:08 PM Re: Danger Levels of ZDDP? [Re: -SyN-]
Ohle_Manezzini Offline
Loc: Pindorama
Above 900 ppm in a 20 weight oil.
Maybe above 1000 in a 30?
1200 in a 40?
1400 in a 50...
But it takes hundreds of thousand miles before ruining it in a normal (low) oil consumption engine.
Edited by Ohle_Manezzini (01/11/17 03:22 PM)
#4299738 - 01/11/17 03:19 PM Re: Danger Levels of ZDDP? [Re: -SyN-]
SR5 Offline
Loc: Down Under
ILSAC grades have ~ 800 ppm Zinc. I would call this minimum rather than optimum.
But Euro 40 grade A3/B4 oils like Edge & M1 0W40 have ~ 1000 ppm Zinc. These Euro cars, BMW's and Porsche and MB's seem to survive fine on a life of 1000 ppm Zinc oil.
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
#4299745 - 01/11/17 03:26 PM Re: Danger Levels of ZDDP? [Re: -SyN-]
901Memphis Offline
Loc: Northern Kentucky
The phosphorus will damage the cat even at lower levels if it starts burning, the reduction in API certified oils was a compromise to stretch the life of the convertor past the required federal emissions warranty.
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
#4299765 - 01/11/17 03:53 PM Re: Danger Levels of ZDDP? [Re: -SyN-]
MotoTribologist Offline
Loc: NJ, USA
The current upper limit on most automobile viscosity grades according to the API is 800 ppm phosphorus. However, like 901Memphis said, any amount is going to damage the cat over time if it is entering the exhaust system. The catalyst doesn't suddenly get effected by phosphorus above 800 ppm and have no reaction below that point. That 800 ppm limit is just an allowable amount that causes slower degradation than higher concentrations.
#4299774 - 01/11/17 04:02 PM Re: Danger Levels of ZDDP? [Re: -SyN-]
Loc: Pindorama
Maybe, instead of 200k mikes life at 800 ppm, it will get 150k miles at 1500 ppm... on a 20 weight.
Edited by Ohle_Manezzini (01/11/17 04:04 PM)
#4299779 - 01/11/17 04:07 PM Re: Danger Levels of ZDDP? [Re: -SyN-]
slacktide_bitog Online   content
Loc: USA
if the car is burning oil, it can
Otherwise it won't do any harm
#4299787 - 01/11/17 04:18 PM Re: Danger Levels of ZDDP? [Re: -SyN-]
-SyN- Offline
Loc: Tornado Alley
Thank you everyone!
#4299806 - 01/11/17 04:44 PM Re: Danger Levels of ZDDP? [Re: SR5]
Michael_P Offline
Loc: .
Furthermore, these Euro cars are designed to consume some oil. When I have put on aftermarket cats, it seems the better quality cat, the less prone it is for plugging up or seeing the dreaded 420 code. Even if you use high zinc oils.
#4299825 - 01/11/17 05:09 PM Re: Danger Levels of ZDDP? [Re: -SyN-]
ShotGun429 Offline
Loc: Dayton,Ohio
How many cats do/did you guys see ruined by high zinc regular oils pre 2006? I doubt very many. BUT I see at least 3 flat tappet cam equipped cars (Stock cams and springs) with one or more lobes gone with the current off the shelf motor oils, fully 50 percent of my customers didnt know they had to run special higher zinc oils to prevent cam failures. I wish they had not messed with our oils.
#4299898 - 01/11/17 07:33 PM Re: Danger Levels of ZDDP? [Re: Miller88]
KCJeep Online   content
Loc: Mahzurrah!
This!
04 Jeep Grand Cherokee 4.0 147k - GTX 5w30/10w40
09 Lincoln MKZ AWD 89k - Magnatec 5w30
12 KIA Sedona 83k - Edge 0w40
09 Ford Focus 127k - GTX UC 5w30
#4299941 - 01/11/17 08:25 PM Re: Danger Levels of ZDDP? [Re: ShotGun429]
JeepWJ19 Offline
Loc: PENNSYLVANIA
My 4.0 has been fine throughout all the years of my ownership using SN PHM and now SN Mobil 1 HM and it was doing just fine from all the shop oil changes per the receipts shown to me by the elderly woman who was sole previous, and original, owner.
I guess I should expect my 4.0 to blow up any day now considering it hasn't been using API SL rated oil for the past 13 years?
Edited by JeepWJ19 (01/11/17 08:29 PM)
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Page 1 of 2 1 2 >
