White car..has white grease
by Vdubuk
04/23/18 02:17 AM
Do you need to change oil if your engine leaks
by Vdubuk
04/23/18 01:35 AM
Castrol Edge 5w30 A3/B4 SCA sale 23-24 April $29
by KL31
04/22/18 10:50 PM
Testing the "oil goes bad with age" theory
by Atomic
04/22/18 09:12 PM
08 Grand Caravan with 156k. ignition problem
by Mark72
04/22/18 09:12 PM
DexOS in a 2005 Cavalier LS?
by GMWeber
04/22/18 09:10 PM
US-Canada mail transit questions..
by earlyre
04/22/18 09:10 PM
hybrid ICE wear
by tigrpal
04/22/18 08:51 PM
03' 2.3 Ford Focus / Dash light on steadly
by Oregoonian
04/22/18 08:47 PM
Tundra vibration
by pda1122
04/22/18 08:39 PM
Who says Corvettes are gas guzzlers?
by Patman
04/22/18 08:26 PM
Mobile rebate question
by Snowball
04/22/18 08:25 PM
Oil shear and 0w,5w,10w?
by Camprunner
04/22/18 05:42 PM
Looks like the Jeep needs axle bearings
by Nick1994
04/22/18 05:13 PM
Toyota OEM Cartridge Filter, Cut Open 12,669 Miles
by Nick1994
04/22/18 04:53 PM
S/C Range Rover, 5000kms 33 different oils UOA
by Vladiator
04/22/18 04:24 PM
Buying oil on price - Pricing Rant
by JHZR2
04/22/18 04:22 PM
Mix of 33 oils VOA
by Vladiator
04/22/18 04:19 PM
Sugar Binge Hangover ... :~/
by LoneRanger
04/22/18 04:18 PM
MagnaFlow 49253 Exhaust Header
by Ambition5253
04/22/18 04:14 PM
daylateetc, Kjammer, sonnyk, PWMDMD, usernameunknown
64820 Registered Users
13 registered (michaelluscher, edyvw, Billbert, csandste, BlueOvalFitter, 3 invisible), 732 Guests and 49 Spiders online.
64820 Members
68 Forums
282162 Topics
Page 1 of 2 1 2 >
#4299545 - 01/11/17 11:56 AM 2012 WRX Oil Choice with regard to LSPI
dirty_projection Offline
Loc: MI - Michigan
Been researching a lot of oils lately and still having trouble deciding on a good robust oil for MY12 WRX which is otherwise stock. Driving habits tend to be a bit rougher than your average user I would say, but not flat out abuse. Looking into M1 0w40 and Castrol 0w30/40.
My concern with both of these oils is their calcium content with respect to LSPI events. I also would rather not have a relatively thin oil in regards to fuel dilution. I would like to keep economy, but with protection to my bearings for when I go flat out. I have no problem with a 5w40 oil, but am trying to stay away from diesel designed oils like rt6, etc due to high calcium levels for soot control in their original design. At work we religiously use M1 5w30/0w20 in most applications from small gas i4 turbos to v6 twin turbos. I haven't been able to find a VOA on a recent M1 5w30 formulation. From what I could find M1 0w40 has high calcium too. I currently have zero oil consumption using Subaru OEM (Idemistu 5w30) from day 1 and ~65k. Going to do an OA through blackstone on my next change too to gauge the overall health.
Any other suggestions welcome. Am trying to stay in the 5w30 category if I can. Other oils I'm looking at are Motul Xclean 5w30, but again can't find a VOA on that. Thanks,
Zak
#4299555 - 01/11/17 12:04 PM Re: 2012 WRX Oil Choice with regard to LSPI [Re: dirty_projection]
Virtus_Probi Offline
Loc: New England
You shouldn't have to worry about LSPI because your engine is not direct injection...LSPI seems to be a DIT problem.
Luckily, you should be able to use pretty much what you want!
My '14 FXT was recalled for LSPI and I have been sticking with M1 products. M1 0W40 is the only product in the line that I am aware of having a large calcium dose. Everything I have seen for M1 5W30, including the EP and ESP flavors, has shown low calcium...the ESP doesn't even use magnesium to replace some of the calcium and has a low starting TBN as a result.
Edited by Virtus_Probi (01/11/17 12:06 PM)
2014 Forester XT, 80500 miles
Last Change;
Valvoline Full Synthetic 5W30 d1G2
Tokyo Roki 15208AA170 filter
#4299560 - 01/11/17 12:10 PM Re: 2012 WRX Oil Choice with regard to LSPI [Re: dirty_projection]
cmhj Offline
Loc: SE Pa
No PC fees paid to Amsoil dealers!
2018 Buick Enclave Essence
2013 Fiat 500
2012 Equinox LS
2016 Subaru Forester 2.5i Touring
A slug of old stuff
#4299600 - 01/11/17 12:55 PM Re: 2012 WRX Oil Choice with regard to LSPI [Re: dirty_projection]
Loc: MI - Michigan
Ah for some reason I could've sworn they went direct injection in 2011, but that makes more sense. And yes it's mainly a direct injection problem. It's something all the automakers are struggling with these days from what I understand. Quite interesting if you have access to the data; unfortunately I am not at liberty to share...The dexos1 rating is the only one I know that has LSPI conditions to be met for oil design btw, so I'd stick with that if you have known LSPI issues. Lucky if it didn't take your piston out! smile Thanks for the info
#4299638 - 01/11/17 01:29 PM Re: 2012 WRX Oil Choice with regard to LSPI [Re: dirty_projection]
wemay Offline
Loc: Southeast Florida
Yes, we have seen quite a bit of data from reputable sources concerning LSPI. Chevron Ornite, SAE and Lubrizol to name a few. But it sounds like your application is outside this scope. Thankfully.
17 Sonata 2.4 |Mobil Super Synthetic 5w20, M1
13 Santa Fe 2.0T |Mobil1 5w30 (d1G2), STP XL
#4299675 - 01/11/17 02:00 PM Re: 2012 WRX Oil Choice with regard to LSPI [Re: dirty_projection]
1JZ_E46 Offline
Loc: Oregon
I don't think you could go wrong with any LL-01 approved oil for your EJ engine. It is probably the hardest oil spec to meet and is designed with small turbo engines in mind (BMW N20). Personal preference, I would stick with Castrol, Motul, or Pennzoil. Euro 5W-30s are a fair amount thicker than a dexos 5W-30.
Edited by 1JZ_E46 (01/11/17 02:00 PM)
2007 BMW X5 4.8i, 105K: Castrol EDGE 0W-40, Mann
2012 Mini Cooper, 45K: Castrol EDGE 0W-30, Mann
#4299761 - 01/11/17 03:47 PM Re: 2012 WRX Oil Choice with regard to LSPI [Re: dirty_projection]
Ohle_Manezzini Offline
Loc: Pindorama
2012 still an EJ? No.
#4299764 - 01/11/17 03:51 PM Re: 2012 WRX Oil Choice with regard to LSPI [Re: Ohle_Manezzini]
bluesubie Offline
Loc: NJ
Yep.
'04 Subaru Forester 2.5XT
Castrol Edge 0W-40
#4299818 - 01/11/17 04:59 PM Re: 2012 WRX Oil Choice with regard to LSPI [Re: dirty_projection]
Dan55 Offline
Loc: Fernandina Beach FL
2016 Lexus NX200T 2017 Mustang Conv Eco Prem
#4299819 - 01/11/17 05:00 PM Re: 2012 WRX Oil Choice with regard to LSPI [Re: dirty_projection]
Dyusik Offline
Loc: US-WA
Zak
RT6 is the lowest Ca formulation I've ever seen.
95 Cherokee 190K DELO 10W30,XG8
07 IS250 96K FB ?w??,FULL
04 YZF-R1 18K DELO 15w40,XG7317
99 HD XL1200S 18K 76 20w50,1515
14 RX450h 30k PP 0w20,NAPAG
#4299821 - 01/11/17 05:04 PM Re: 2012 WRX Oil Choice with regard to LSPI [Re: dirty_projection]
E150GT Offline
Loc: San Antonio, TX
I just googled LSPI and now I'm wondering does this only occur in direct injected turbo engines or any direct injection engine?
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5 speed - 247k 5w30
2016 Mazda 6 manual 6speed - 46k 5w30
#4300096 - 01/12/17 01:11 AM Re: 2012 WRX Oil Choice with regard to LSPI [Re: dirty_projection]
Loc: MI - Michigan
It's mainly due to a lot of increased pressures in the cylinder and causes ignition that is uncontrolled and it happens before the spark, so you have ignition before the spark occurs. When the spark occurs it then ignites the mixture even more and causes pressures that are far beyond design scope for small displacement turbo applications. It kind of acts like a diesel cycle where the pressure ignites the mixture, but then you add spark to the factor and it basically acts like a small bomb. It is not uncommon for these instances to completely melt through the piston creating a hole in the general middle location of the piston. As for why, well that's still a theory at this point. There isn't a huge amount of concrete proof to say exactly why from what I know. Maybe someone with more direct hands on experience could elaborate more as I am fairly new to this research.
#4300097 - 01/12/17 01:34 AM Re: 2012 WRX Oil Choice with regard to LSPI [Re: Dyusik]
Loc: MI - Michigan
See with recent RT6 changes I have been hesitant to use that, plus I am curious about the RT6 multi vehicle use in 5w30.
#4300189 - 01/12/17 07:28 AM Re: 2012 WRX Oil Choice with regard to LSPI [Re: dirty_projection]
bluesubie Offline
Loc: NJ
See with recent RT6 changes I have been hesitant to use that,.
Why? Because of higher ZDDP?
Edited by bluesubie (01/12/17 07:38 AM)
Castrol Edge 0W-40
#4300202 - 01/12/17 07:40 AM Re: 2012 WRX Oil Choice with regard to LSPI [Re: dirty_projection]
Loc: New England
I looked into RT6 a while back because it was so popular with WRX/FXT drivers, but I wasn't too impressed with the NOACK from the PQIA analysis (12.8%) and its CCS viscosity was about 50% higher than M1 5W30 at -30C. I did like the low calcium dose!
http://www.pqiamerica.com/June%202014/shellrotellat6.htm
Last Change;
Page 1 of 2 1 2 >
