Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
15 minutes 27 seconds ago
what happened to merk
by ernied
26 minutes 53 seconds ago
Schaeffer's oil reviews on Amazon
by zfasts03
Today at 07:41 PM
Decent MP3 player
by Ed_T
Today at 07:08 PM
Letgo
by Donald
Today at 06:52 PM
Tire buying advice
by supton
Today at 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
Today at 06:21 PM
No older cars in New York State?
by Oldtom
Today at 06:19 PM
2009 Taurus strut mount noise
by terry274
Today at 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
Today at 03:36 PM
2003 Honda power steering problem
by hogpops
Today at 03:29 PM
Public Service Announcement: Flush Your HW Heater
by gathermewool
Today at 03:25 PM
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
Today at 03:21 PM
Castrol 0W40 vs 5W40??
by Realfine69
Today at 03:02 PM
Paint impurities on a new car
by Quattro Pete
Today at 02:49 PM
2014 Ram wheel FIT on a 2005 Ram?
by SumpChump
Today at 02:41 PM
Do people buy from telemarketers?
by Chris142
Today at 02:06 PM
TGMO 0W20, 8100km/5mo, 2013 Lexus GS350AWD 118K KM
by David_Corbett
Today at 01:54 PM
Sonoma Raceway
by Warstud
Today at 01:51 PM
Zipcode error
by aquariuscsm
Today at 01:36 PM
crrider, EdDmax, 2018matto, Lancruza, IanSampson
65312 Registered Users
116 registered (2015_PSD, 2009Edge, Alex_V, 69Torino, 87sammy, 1nighttrain, 6 invisible), 1452 Guests and 69 Spiders online.
65312 Members
67 Forums
285939 Topics
Page 1 of 4 1 2 3 4 >
#4299429 - 01/11/17 09:44 AM Oil filter with multiple oil changes
Matagonka Offline
Loc: NC
Let's say you use your Fram Ultra or Mobil 1 EP for 2 or even 3 oil changes...
Do you remove the filter and drain out the old oil from the filter as well, or just drain the engine and let the little amount of oil in the filter mix in with the new engine oil?
#4299433 - 01/11/17 09:47 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
AntsinmyEyes Offline
Loc: Colorado
leave the filter on. the seal is one time use
1987 mazda rx7
2004 mazda rx8
1995 miata
2005 dodge ram
#4299435 - 01/11/17 09:48 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
440Magnum Offline
Loc: Texas
Leave it on. The filter gasket isn't made to seal, come off, and then seal again.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
#4299437 - 01/11/17 09:50 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
TinyVoices Offline
Loc: Vienna, VA
As others have said, leave it on.
1993 Toyota MR2 Hardtop N/A - 157k miles - Valvoline Max Life 5w30
2006 Toyota Matrix XR AWD (Fiancee) - 126k miles - Valvoline Max Life 5w30
#4299447 - 01/11/17 10:01 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
I loosen the filer, then re-tighten. Many vehicles today are designed so the filter sits in a manner where half of it's contents will depart. Also a number of vehicles exist today that are designed with oil channels that sit right above the top of the filter threads. These oil channels will empty also.
So in most cases today, no need to remove the old filter, then re-tighten it. Just loosen it half-way, then tighten it.
Also, I don't oil my filter gasket, when I initially install it new. I use Gorilla Grease on the gasket and there's no need to apply anything more to the gasket, when re-tightening it. That particular grease is like an anti-seize lubricant. So it eases removal.
Edited by Triple_Se7en (01/11/17 10:04 AM)
#4299449 - 01/11/17 10:02 AM Re: Oil filter with multiple oil changes [Re: TinyVoices]
jacky Offline
Loc: wv usa
I would never use any filter for more than one oil change, but I would like to see pics of a a filter from that situation
2001 chevy cavalier 148,000
#4299451 - 01/11/17 10:05 AM Re: Oil filter with multiple oil changes [Re: jacky]
Matagonka Offline
Loc: NC
There are multiple threads with cut open oil filters that were used for more than 1 OC.
#4299453 - 01/11/17 10:09 AM Re: Oil filter with multiple oil changes [Re: jacky]
TinyVoices Offline
Loc: Vienna, VA
Tons of cut and post threads of oil filter from multiple OCIs.
#4299471 - 01/11/17 10:29 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
Kuato Offline
Loc: Colorado
Leave it on in between.
Thick vs Thin test: 15k / 43k miles complete
#4299473 - 01/11/17 10:33 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
THafeez Offline
Loc: New Jersey
Leave it on. I asked this specific question to a FRAM representative. They said not to take it off because the seal can only be used once. The warranty on their filter is also void if you take it off between OCI's because the gaskets seal is compromised.
2004 Toyota Solara SE 2.4 2AZFE
175,000 miles
Valvoline Synpower Maxlife 5W30
Royal Purple 20-400 oversize
#4299479 - 01/11/17 10:37 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
Bgallagher Offline
Loc: Boston, MA
I did that with a mobil 1 extended. I have one more filter left. I drained the oil, refilled and left the filter on. I will replace the filter the next oil change before I hopefully trade it in
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
#4299494 - 01/11/17 11:01 AM Re: Oil filter with multiple oil changes [Re: jacky]
Hokiefyd Offline
Loc: Top of Virginia
An oil filter used for two 5,000 mile oil change intervals will look absolutely no different from an oil filter used for one 10,000 mile oil change. Oil change intervals doshould not dictate the oil filter change interval. The filter change interval should be commensurate with the type and quality of the filter.
#4299499 - 01/11/17 11:09 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
BrocLuno Offline
Loc: Kalifornia Kollective
As I have stated before, the State Fleet Admin ran tests years ago and determined that the most cost effective strategy to long tern vehicle ownership is oil changes every 6K and filters every other time. There are also paper over in technical that describe the benefits of retained oil at the time of change. the consensus is that 10~20% retained is best.
This has to do with AW compounds that your engine makes as oil ages in the motor. Fresh oil has none of these. 80% replacement will get the TBN back up and the oil clean enough. and the benefits of the retained oil will do until the new stuff has had a chance to make some.
So I'm going at least two changes. Shannow and I are changing the filters a week or two after the second oil change so that the retained is doing its job.
The life of filters and oil are not coincidental. Changing both is a matter of convenience for the guy on the ground or in the pit. Oil gets dirty, contaminated with chemical by-products of combustion, changes it viscosity by shearing, etc. Only the dirty part impacts the filter. And it takes a lot more dirt and soot than one OCI to do in a filter.
Ideally filters would be changed like in marine and stationary when the differential gauge pressures on both side said they needed to be changed. The oil would be changed based on UOA's. In this scenario, the two never coincide. Cars are just done the way they are because of convenience and caution ...
#4299505 - 01/11/17 11:14 AM Re: Oil filter with multiple oil changes [Re: Triple_Se7en]
hatt Online   content
Loc: Florida
Sounds like a recipe to make a mess and get contaminants into the system/seal. If I went thought the trouble to mess with it I'd simply change it.
2013 F150 5.0, PUP 10W-30, Wix 57502
2010 Camry 2.5, GTX 5W-20, Fram Ultra XG9972
#4299516 - 01/11/17 11:25 AM Re: Oil filter with multiple oil changes [Re: BrocLuno]
Ramblejam Offline
Loc: Kentucky
Have you ever provided a link to this report?
California OFAM follows this (oil and filter changed every 6,000 miles or 6 months normal use, or 4,000 miles severe use): https://www.documents.dgs.ca.gov/dgs/fmc/gs/ofam/dgsofam0035.pdf
