Cheap oil filter cutters?
by irv
04/25/18 11:02 AM
Ford 1.5 EcoBoost P2243
by dogememe
04/25/18 10:24 AM
Ethanol free gas
by CT8
04/25/18 09:40 AM
Husq 322L, how to convert to brush cutter?
by andyd
04/25/18 08:37 AM
Do you ever use a gear selection other than D?
by ZZman
04/25/18 08:00 AM
BITOG Detail and Wax - Top Picks
by gofast182
04/25/18 07:32 AM
Inherited gallons of Amsoil 40wt oils all cars 30w
by Rmay635703
04/25/18 06:47 AM
Oil Filter Recommendations for a 82 trans am
by GMguy84
04/25/18 05:24 AM
Teflon tape vs. paste
by dlundblad
04/25/18 04:13 AM
Shelf life of various fluids?
by Chris B.
04/25/18 03:56 AM
Shelf life of unopened/opened oil?
by Chris B.
04/25/18 03:49 AM
Is there a search or filter option?
by MellieK
04/25/18 01:32 AM
The Cuban Sandwich
by BlueOvalFitter
04/25/18 12:46 AM
Can't decide...but I need another pal
by Marco620
04/25/18 12:36 AM
We Will Remember Them.
by Silk
04/25/18 12:28 AM
Venezuela Arrests US Chevron Employees for Treason
by Nyogtha
04/24/18 11:19 PM
Classwork, Homework, and Exam
by Shannow
04/24/18 09:50 PM
Hydroflouric Acid as Aluminum cleaner,deoxidizer
by daves66nova
04/24/18 09:10 PM
I asked Valvoline about Seq IVA
by Carbon12
04/24/18 08:42 PM
Motor teardown?
by Sealbilly
04/24/18 08:09 PM
emod, Rmay635703, Rabbits, Poolcueti, Burrito97
64846 Registered Users
102 registered (1JZ_E46, 28oz, 853okg, 14Accent, 69Torino, aquariuscsm, 6 invisible), 1891 Guests and 59 Spiders online.
64846 Members
68 Forums
282314 Topics
Page 1 of 4 1 2 3 4 >
#4299429 - 01/11/17 09:44 AM Oil filter with multiple oil changes
Matagonka Offline
Loc: NC
Let's say you use your Fram Ultra or Mobil 1 EP for 2 or even 3 oil changes...
Do you remove the filter and drain out the old oil from the filter as well, or just drain the engine and let the little amount of oil in the filter mix in with the new engine oil?
#4299433 - 01/11/17 09:47 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
AntsinmyEyes Offline
Loc: Colorado
leave the filter on. the seal is one time use
1987 mazda rx7 1.3
2004 mazda rx8 1.3
2005 dodge ram 5.7
2004 saturn ion 2.2
#4299435 - 01/11/17 09:48 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
440Magnum Offline
Loc: Texas
Leave it on. The filter gasket isn't made to seal, come off, and then seal again.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
#4299437 - 01/11/17 09:50 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
TinyVoices Offline
Loc: Vienna, VA
As others have said, leave it on.
1993 Toyota MR2 Hardtop N/A - 157k miles - Valvoline Max Life 5w30
2006 Toyota Matrix XR AWD (Fiancee) - 126k miles - Valvoline Max Life 5w30
#4299447 - 01/11/17 10:01 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
I loosen the filer, then re-tighten. Many vehicles today are designed so the filter sits in a manner where half of it's contents will depart. Also a number of vehicles exist today that are designed with oil channels that sit right above the top of the filter threads. These oil channels will empty also.
So in most cases today, no need to remove the old filter, then re-tighten it. Just loosen it half-way, then tighten it.
Also, I don't oil my filter gasket, when I initially install it new. I use Gorilla Grease on the gasket and there's no need to apply anything more to the gasket, when re-tightening it. That particular grease is like an anti-seize lubricant. So it eases removal.
Edited by Triple_Se7en (01/11/17 10:04 AM)
#4299449 - 01/11/17 10:02 AM Re: Oil filter with multiple oil changes [Re: TinyVoices]
jacky Offline
Loc: wv usa
I would never use any filter for more than one oil change, but I would like to see pics of a a filter from that situation
2001 chevy cavalier 148,000
#4299451 - 01/11/17 10:05 AM Re: Oil filter with multiple oil changes [Re: jacky]
Matagonka Offline
Loc: NC
There are multiple threads with cut open oil filters that were used for more than 1 OC.
#4299453 - 01/11/17 10:09 AM Re: Oil filter with multiple oil changes [Re: jacky]
TinyVoices Offline
Loc: Vienna, VA
Tons of cut and post threads of oil filter from multiple OCIs.
#4299471 - 01/11/17 10:29 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
Kuato Offline
Loc: Colorado
Leave it on in between.
Thick vs Thin test: 15k / 43k miles complete
#4299473 - 01/11/17 10:33 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
THafeez Offline
Loc: New Jersey
Leave it on. I asked this specific question to a FRAM representative. They said not to take it off because the seal can only be used once. The warranty on their filter is also void if you take it off between OCI's because the gaskets seal is compromised.
2004 Toyota Solara SE 2.4 2AZFE
175,000 miles
Valvoline Synpower Maxlife 5W30
Royal Purple 20-400 oversize
#4299479 - 01/11/17 10:37 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
Bgallagher Offline
Loc: Boston, MA
I did that with a mobil 1 extended. I have one more filter left. I drained the oil, refilled and left the filter on. I will replace the filter the next oil change before I hopefully trade it in
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
#4299494 - 01/11/17 11:01 AM Re: Oil filter with multiple oil changes [Re: jacky]
Hokiefyd Offline
Loc: Top of Virginia
An oil filter used for two 5,000 mile oil change intervals will look absolutely no different from an oil filter used for one 10,000 mile oil change. Oil change intervals doshould not dictate the oil filter change interval. The filter change interval should be commensurate with the type and quality of the filter.
#4299499 - 01/11/17 11:09 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
BrocLuno Offline
Loc: Kalifornia Kollective
As I have stated before, the State Fleet Admin ran tests years ago and determined that the most cost effective strategy to long tern vehicle ownership is oil changes every 6K and filters every other time. There are also paper over in technical that describe the benefits of retained oil at the time of change. the consensus is that 10~20% retained is best.
This has to do with AW compounds that your engine makes as oil ages in the motor. Fresh oil has none of these. 80% replacement will get the TBN back up and the oil clean enough. and the benefits of the retained oil will do until the new stuff has had a chance to make some.
So I'm going at least two changes. Shannow and I are changing the filters a week or two after the second oil change so that the retained is doing its job.
The life of filters and oil are not coincidental. Changing both is a matter of convenience for the guy on the ground or in the pit. Oil gets dirty, contaminated with chemical by-products of combustion, changes it viscosity by shearing, etc. Only the dirty part impacts the filter. And it takes a lot more dirt and soot than one OCI to do in a filter.
Ideally filters would be changed like in marine and stationary when the differential gauge pressures on both side said they needed to be changed. The oil would be changed based on UOA's. In this scenario, the two never coincide. Cars are just done the way they are because of convenience and caution ...
#4299505 - 01/11/17 11:14 AM Re: Oil filter with multiple oil changes [Re: Triple_Se7en]
hatt Online   content
Loc: Florida
Sounds like a recipe to make a mess and get contaminants into the system/seal. If I went thought the trouble to mess with it I'd simply change it.
2013 F150 5.0, Pennzoil Ultra 10W-30, Wix
2010 Camry 2.5, GTX 5W-20, Fram Ultra XG9972
#4299516 - 01/11/17 11:25 AM Re: Oil filter with multiple oil changes [Re: BrocLuno]
Ramblejam Offline
Loc: Kentucky
Have you ever provided a link to this report?
California OFAM follows this (oil and filter changed every 6,000 miles or 6 months normal use, or 4,000 miles severe use): https://www.documents.dgs.ca.gov/dgs/fmc/gs/ofam/dgsofam0035.pdf
