Can't believe I fixed it
by Stelth
02/25/18 04:40 PM
Cruise Control Set at 55
by das_peikko
02/25/18 04:39 PM
Who here has satellite radio in your vehicle?
by ZZman
02/25/18 04:01 PM
Oil choice for new to me 07 escape V6
by gabriel9766
02/25/18 03:10 PM
Super cleaning windshield
by mclasser
02/25/18 02:36 PM
New WM oil filters...
by rollinpete
02/25/18 01:49 PM
Swapped Out Bunch of Indoor Flood Bulbs to LED ...
by LoneRanger
02/25/18 01:45 PM
Scanner ABS Transmission and Engine Codes reader.
by littleant
02/25/18 01:38 PM
Meijer - Quaker State buy one, get one 50% off
by Bighorn2500
02/25/18 12:50 PM
Anyone own a 3rd generation Toyota Tacoma
by 007
02/25/18 12:47 PM
Best "wax as you dry" type spray wax?
by aquariuscsm
02/25/18 12:39 PM
Any current Edge 0W20 users here ?
by aquariuscsm
02/25/18 12:27 PM
Which one?
by RogerBacon
02/25/18 12:25 PM
VW Polo, 1.4 TSI 150hp (ea211) 0w-30. 11700km
by VTS16
02/25/18 12:16 PM
Atlanta Quick Trip 500
by bdcardinal
02/25/18 11:58 AM
Gumout One N Done vs All In One
by Patman
02/25/18 11:44 AM
ACEA A5/B5 vs ACEA A3/B4 for Volvo V60 Polestar?
by A1ex
02/25/18 11:36 AM
Vogue Signature V tire review
by 2strokeNorthstar
02/25/18 11:33 AM
Which have improved faster - engines or oils?
by HawkeyeScott
02/25/18 11:12 AM
PP 5W20 bottom of jug debris
by aquariuscsm
02/25/18 11:05 AM
A1ex, Grozd, swc, coronad0, davidsain
64288 Registered Users
94 registered (08versa, andrewp1998, A1ex, AnonOIl, 2015_PSD, ammolab, 5 invisible), 1854 Guests and 93 Spiders online.
64288 Members
65 Forums
278790 Topics
Page 1 of 4 1 2 3 4 >
#4299429 - 01/11/17 09:44 AM Oil filter with multiple oil changes
Matagonka Offline
Loc: NC
Let's say you use your Fram Ultra or Mobil 1 EP for 2 or even 3 oil changes...
Do you remove the filter and drain out the old oil from the filter as well, or just drain the engine and let the little amount of oil in the filter mix in with the new engine oil?
2005 Honda Accord V6 - 179k (CE-HM 5w-30/W Fram Ultra)
2013 Hyundai Santa Fe Sport - 105K(QSUD)
#4299433 - 01/11/17 09:47 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
AntsinmyEyes Offline
Loc: Colorado
leave the filter on. the seal is one time use
1987 mazda rx7 1.3
2004 mazda rx8 1.3
2005 dodge ram 5.7
2004 saturn ion 2.2
#4299435 - 01/11/17 09:48 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
440Magnum Offline
Loc: Texas
Leave it on. The filter gasket isn't made to seal, come off, and then seal again.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
#4299437 - 01/11/17 09:50 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
TinyVoices Offline
Loc: Vienna, VA
As others have said, leave it on.
1993 Toyota MR2 Hardtop N/A - 157k miles - Valvoline Max Life 5w30
2006 Toyota Matrix XR AWD (Fiancee) - 126k miles - Valvoline Max Life 5w30
#4299447 - 01/11/17 10:01 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
I loosen the filer, then re-tighten. Many vehicles today are designed so the filter sits in a manner where half of it's contents will depart. Also a number of vehicles exist today that are designed with oil channels that sit right above the top of the filter threads. These oil channels will empty also.
So in most cases today, no need to remove the old filter, then re-tighten it. Just loosen it half-way, then tighten it.
Also, I don't oil my filter gasket, when I initially install it new. I use Gorilla Grease on the gasket and there's no need to apply anything more to the gasket, when re-tightening it. That particular grease is like an anti-seize lubricant. So it eases removal.
Edited by Triple_Se7en (01/11/17 10:04 AM)
#4299449 - 01/11/17 10:02 AM Re: Oil filter with multiple oil changes [Re: TinyVoices]
jacky Offline
Loc: wv usa
I would never use any filter for more than one oil change, but I would like to see pics of a a filter from that situation
2001 chevy cavalier 148,000
#4299451 - 01/11/17 10:05 AM Re: Oil filter with multiple oil changes [Re: jacky]
Matagonka Offline
Loc: NC
There are multiple threads with cut open oil filters that were used for more than 1 OC.
#4299453 - 01/11/17 10:09 AM Re: Oil filter with multiple oil changes [Re: jacky]
TinyVoices Offline
Loc: Vienna, VA
Tons of cut and post threads of oil filter from multiple OCIs.
#4299471 - 01/11/17 10:29 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
Kuato Offline
Loc: Colorado
Leave it on in between.
Thick vs Thin test: 15k / 43k miles complete
#4299473 - 01/11/17 10:33 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
THafeez Offline
Loc: New Jersey
Leave it on. I asked this specific question to a FRAM representative. They said not to take it off because the seal can only be used once. The warranty on their filter is also void if you take it off between OCI's because the gaskets seal is compromised.
2004 Toyota Solara SE 2.4 2AZFE
170,000 miles
Belgian Castrol 0W30
Bosch Distance Plus D3421
#4299479 - 01/11/17 10:37 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
Bgallagher Offline
Loc: Boston, MA
I did that with a mobil 1 extended. I have one more filter left. I drained the oil, refilled and left the filter on. I will replace the filter the next oil change before I hopefully trade it in
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
#4299494 - 01/11/17 11:01 AM Re: Oil filter with multiple oil changes [Re: jacky]
Hokiefyd Offline
Loc: Top of Virginia
An oil filter used for two 5,000 mile oil change intervals will look absolutely no different from an oil filter used for one 10,000 mile oil change. Oil change intervals doshould not dictate the oil filter change interval. The filter change interval should be commensurate with the type and quality of the filter.
#4299499 - 01/11/17 11:09 AM Re: Oil filter with multiple oil changes [Re: Matagonka]
BrocLuno Offline
Loc: Kalifornia Kollective
As I have stated before, the State Fleet Admin ran tests years ago and determined that the most cost effective strategy to long tern vehicle ownership is oil changes every 6K and filters every other time. There are also paper over in technical that describe the benefits of retained oil at the time of change. the consensus is that 10~20% retained is best.
This has to do with AW compounds that your engine makes as oil ages in the motor. Fresh oil has none of these. 80% replacement will get the TBN back up and the oil clean enough. and the benefits of the retained oil will do until the new stuff has had a chance to make some.
So I'm going at least two changes. Shannow and I are changing the filters a week or two after the second oil change so that the retained is doing its job.
The life of filters and oil are not coincidental. Changing both is a matter of convenience for the guy on the ground or in the pit. Oil gets dirty, contaminated with chemical by-products of combustion, changes it viscosity by shearing, etc. Only the dirty part impacts the filter. And it takes a lot more dirt and soot than one OCI to do in a filter.
Ideally filters would be changed like in marine and stationary when the differential gauge pressures on both side said they needed to be changed. The oil would be changed based on UOA's. In this scenario, the two never coincide. Cars are just done the way they are because of convenience and caution ...
#4299505 - 01/11/17 11:14 AM Re: Oil filter with multiple oil changes [Re: Triple_Se7en]
hatt Offline
Loc: Florida
Sounds like a recipe to make a mess and get contaminants into the system/seal. If I went thought the trouble to mess with it I'd simply change it.
2013 F150 5.0, Delo 15w-30, Baldwin B7449
2010 Camry 2.5, PP 10w-30, Fram Ultra XG9972
#4299516 - 01/11/17 11:25 AM Re: Oil filter with multiple oil changes [Re: BrocLuno]
Ramblejam Offline
Loc: Kentucky
Have you ever provided a link to this report?
California OFAM follows this (oil and filter changed every 6,000 miles or 6 months normal use, or 4,000 miles severe use): https://www.documents.dgs.ca.gov/dgs/fmc/gs/ofam/dgsofam0035.pdf
