Disassembled my front passenger CV axle to clean and replace grease and boots with Volvo OEM boot kits I ordered and before I tightened the clamps on both boots, as I was moving the axle from one location to another, the inner boot popped off and the fresh thin yellow inner joint grease dumped out. Contaminated with who knows what I couldn't just scoop it up and put back in the axle. Volvo parts department doesn't sell just this grease. Both inner and outer grease packs (outer boot grease was dark grey thick moly ) were labeled as manufactured by Ford; the inner boot packed labeled as "G-PS".
Besides buying another expensive Volvo boot kit, where in the world can I can get this stuff or something similar in composition that would be compatible with what's currently in there? I would hate to have to disassemble again to reclean in the event the replacement grease is possibly incompatible with what thin light yellow (Ford G-PS) grease is still in there.
Packet states the following: "Contains Reaction products of 4-methyl-2-pentanol and diphosphorus pentasulfide, propoxylated, esterified with diphosphorus pentaoxide, and salted by amines, C12-14-tert-alkyl."
Neither Volvo nor Ford parts departments can get this. A Google search for Ford G-PS grease only turns up an MSDS sheet.
Thanks in advance.
Thanks in advance.
