Ran into BJ's last night for some household supplies, and spied 6qt case for $20, Mobil Super Synthetic. From what I understand, it's a middle of the road snythetic. Is it "better" than Maxlife high mileage blend? Walmart has Maxlife at $17 and change; that makes this MSS slightly cheaper per qt.
I grabbed two cases as it's 3 oil changes, so I'm asking at the wrong time, but felt like asking anyhow. I might go back and get more; I'm not sure when I'll go back to 5k OCI's on this old Camry (depends upon what I find in the oil filter this weekend).
Car that I intend to use in is a '99 Camry, with a weeping valvecover gasket (which I'll fix, eventually). When I bought the car it had Quaker State (something) in it, and I don't think it had any leaks. I put in Maxlife, did 2,500 miles, found crud in the filter. Just about to 2,500 miles again, so I figured I'd change again, so as to reassess what is going on in the motor. Not sure what usage was in the past, I suspect short trips for the last few--right now it's spending lots of time on the highway.
