I replaced the PCV valve on my '99 Camry this weekend, as I broke plastic on it in the 10F weather. I picked up an Autozone valve and put it back together. Question: should I buy an OEM one? Sometimes you get what you pay for, and in this case I just wanted the car moving again. Not sure how "good" an AZ PCV is.
It was Autozone PCV2301DL, if it matters, not the Fram or any other brand.
