75% of the time when cooking I will use either a Calphalon frying pan, which are simply hard anodized aluminum, or Corning Visions Cranberry colour glass (no longer made) pots mostly.
Don't forget properly seasoned cast iron. I have some smaller ones I use to cook one egg for "McMuffins" or to make a Denver Sandwich.
Plus I also have a set of good quality (stainless, not glass, lids is your primary indicator) Cuisinart pots & pans that are triple ply with the internal element going up the sides as well as encapsulated on the base. They are bare stainless on the outside layer, no non-stick anything, and they clean up perfectly. The bonus is you can use crusted meat to create glazes and gravies with this type of pot or pan.
The problem with non-stick coatings is they are not to be used with anything higher than medium heat. The non-coating types (anodized, glass, cast iron) can take the heat without an added coating breaking down and contaminating the food you are eating.
