2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
what happened to merk
by ernied
06/24/18 08:34 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
2003 Honda power steering problem
by hogpops
06/24/18 03:29 PM
Public Service Announcement: Flush Your HW Heater
by gathermewool
06/24/18 03:25 PM
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
06/24/18 03:21 PM
lozpxs, danthemanx07, FunktasticLucky, Knuckle078, penncove
65317 Registered Users
25 registered (dishdude, bcwang, Brad_C, chainblu, Dyusik, Bailes1992, 1 invisible), 881 Guests and 38 Spiders online.
65317 Members
67 Forums
285952 Topics
Page 1 of 2 1 2 >
#4297085 - 01/08/17 07:40 PM Lube for squeaky interior door hinges
dishdude Online   content
Loc: Phoenix
WD-40 is the obvious choice, but I don't want the mess that comes with it. Any other alternatives that won't cause an oily mess?
2018 Challenger SRT
#4297089 - 01/08/17 07:44 PM Re: Lube for squeaky interior door hinges [Re: dishdude]
mjoekingz28 Online   content
Loc: United States of America
Look into the penetrants and solvents sub-forums..
#4297090 - 01/08/17 07:47 PM Re: Lube for squeaky interior door hinges [Re: dishdude]
bioburner Offline
Loc: Minnesota
Can try smear in candle wax. The soy base ones are pretty good
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4297103 - 01/08/17 07:56 PM Re: Lube for squeaky interior door hinges [Re: dishdude]
motor_oil_madman Offline
Loc: Houston, Texas
I used Johnson/evinrude blue marine grease and it worked good for a couple years. Just spread a tab on the part that spins, assuming you're talking about car door hinges. I only used it because I don't use it much on anything and I liked the color.
Edited by motor_oil_madman (01/08/17 07:56 PM)
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#4297111 - 01/08/17 08:03 PM Re: Lube for squeaky interior door hinges [Re: dishdude]
Pop_Rivit Offline
Loc: Midwest
Pop the pin out of the hinge and clean it. Then clean the hinges themselves, and before you put the pin back in lightly wax it with beeswax.
#4297138 - 01/08/17 08:26 PM Re: Lube for squeaky interior door hinges [Re: dishdude]
rooflessVW Offline
Loc: North Carolina
Repeat after me: "WD-40 is not a lubricant"
I use a light coat of whatever grease I have handy. Typically Valvoline Syn-Power. I have also popped the hinge pin up a bit a dropped in a little motor oil. Both seem to have worked more or less permanently.
"Zed's dead baby, Zed's dead."
#4297139 - 01/08/17 08:28 PM Re: Lube for squeaky interior door hinges [Re: dishdude]
Ethan1 Offline
Loc: 'murica
I like to remove and clean the hinges, apply massive amounts of white lithium grease, and shove the pin back in until the grease runs out everywhere. There's probably a better grease for the application, but white lithium grease in a tube is cheap.
#4297152 - 01/08/17 08:35 PM Re: Lube for squeaky interior door hinges [Re: dishdude]
Bluestream Offline
Loc: Waterloo, ON
Superlube
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#4297171 - 01/08/17 09:00 PM Re: Lube for squeaky interior door hinges [Re: dishdude]
barkingspider Offline
Loc: socal
I use silicone spray lube.
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
#4297172 - 01/08/17 09:00 PM Re: Lube for squeaky interior door hinges [Re: dishdude]
earlyre Offline
Loc: Lima, Ohio, USA
i've used 5w20 in an oil can/parts oiler.
put a drop in each hinge seam and swing door back and forth until the squeaking stops..
Mine:
09 Mercury Sable : 6qts AutoQuest(Meijer/Warren) 0w20, WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts VWB 5w30,WIX 51394
#4297174 - 01/08/17 09:06 PM Re: Lube for squeaky interior door hinges [Re: Pop_Rivit]
Loc: Phoenix
I would do this, but is seems to be common out West that the builders paint the hinges. Of course mine are painted, and I don't want to chip all the paint off.
2018 Challenger SRT
#4297191 - 01/08/17 09:27 PM Re: Lube for squeaky interior door hinges [Re: dishdude]
Brad_C Online   content
Loc: Perth, Western Australia
That makes it hard. I've used silicone spray lube to do that. It penetrates and doesn't make a mess, but it also doesn't last more than 6 or so months in my experience. I always knock the pins out now and put them back with a couple of drops of Amsoil ISO46 compressor oil (it's just what I keep handy in a syringe). Any good oil or grease will do a credible job. I like the sound of beeswax too.
Any hinge I've done in the last 5 years by knocking out the pin and doing it properly has not yet had to be revisited. If you use a fine punch you can knock the pin out only damaging a spot of paint on the pin top and bottom (you need to use a fine punch to knock it back in to save blowing all the paint off the head). You then need to use a lubricant that won't stain the paint as it leaches out of the joins between the halves.
Or just use silicone spray and be prepared to re-do it every 6 months.
#4297211 - 01/08/17 09:56 PM Re: Lube for squeaky interior door hinges [Re: dishdude]
Fsharp Offline
Loc: Kentucky
Use something without a messy aerosol spray. A drop or two of light oil, like 3 in one oil or similar and wipe off any excess. I've got a bottle of Lubegard Universal Lube I use for things like this.
#4297225 - 01/08/17 10:10 PM Re: Lube for squeaky interior door hinges [Re: Fsharp]
fields Offline
Loc: TX
Best is a wax if your hinges are painted. You can get into problems repainting with some of the suggestions here. Beeswax, gulfwax-whatever.
#4297242 - 01/08/17 10:22 PM Re: Lube for squeaky interior door hinges [Re: dishdude]
RedOakRanch Offline
Loc: Central Coast California
I like the wax idea. I pop the pins out and scratch them with coarse sandpaper then lightly coat with red grease. Never had an issue. If the door swings open or closed on its own then bend the pin slightly before re installing.
1994 Ford Crown Vic 206k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 178k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 56k-M1 EP 0w20 $2/qt
Page 1 of 2 1 2 >
