Originally Posted By: JimPghPA
Originally Posted By: Bluestream
Can you push it into a garage that is warm? Plug in the block heater maybe...The old timers used to drain the oil out at night and put it on a stove to keep warm.
On my 1975 Dodge Van I had to slide a Coleman camp stove under the oil pan for a few hours at -40. She fired right up after that.
I always had trouble with remote starters starting engines at extreme low temps. Not sure way that was, but I dont use them any more.
Sounds like a good way to burn the car down.
I once used a burning diesel-trenched rug under the oil pan to get my w123 diesel started. -20° and 15w-40 in an asthmatic 2 Liter naturally aspirated diesel are not a good combination.
Btw, the russian Ural trucks have/used to have a hook under the engine to hold a gas torch in place facing the oil pan.
