Do you need to change oil if your engine leaks
by Vdubuk
04/23/18 01:35 AM
Castrol Edge 5w30 A3/B4 SCA sale 23-24 April $29
by KL31
04/22/18 10:50 PM
Testing the "oil goes bad with age" theory
by Atomic
04/22/18 09:12 PM
08 Grand Caravan with 156k. ignition problem
by Mark72
04/22/18 09:12 PM
DexOS in a 2005 Cavalier LS?
by GMWeber
04/22/18 09:10 PM
US-Canada mail transit questions..
by earlyre
04/22/18 09:10 PM
hybrid ICE wear
by tigrpal
04/22/18 08:51 PM
03' 2.3 Ford Focus / Dash light on steadly
by Oregoonian
04/22/18 08:47 PM
Tundra vibration
by pda1122
04/22/18 08:39 PM
Who says Corvettes are gas guzzlers?
by Patman
04/22/18 08:26 PM
Mobile rebate question
by Snowball
04/22/18 08:25 PM
Oil shear and 0w,5w,10w?
by Camprunner
04/22/18 05:42 PM
Looks like the Jeep needs axle bearings
by Nick1994
04/22/18 05:13 PM
Toyota OEM Cartridge Filter, Cut Open 12,669 Miles
by Nick1994
04/22/18 04:53 PM
S/C Range Rover, 5000kms 33 different oils UOA
by Vladiator
04/22/18 04:24 PM
Buying oil on price - Pricing Rant
by JHZR2
04/22/18 04:22 PM
Mix of 33 oils VOA
by Vladiator
04/22/18 04:19 PM
Sugar Binge Hangover ... :~/
by LoneRanger
04/22/18 04:18 PM
MagnaFlow 49253 Exhaust Header
by Ambition5253
04/22/18 04:14 PM
Difference between NGK BR6ES and BPR6ES ?!?
by webfors
04/22/18 04:08 PM
daylateetc, Kjammer, sonnyk, PWMDMD, usernameunknown
64820 Registered Users
12 registered (edyvw, Billbert, csandste, BlueOvalFitter, Malo83, 3 invisible), 753 Guests and 46 Spiders online.
64820 Members
68 Forums
282162 Topics
Page 2 of 6 < 1 2 3 4 5 6 >
#4294684 - 01/06/17 06:29 AM Re: Leaving the engine run All night long (all night) [Re: veryHeavy]
KrisZ Offline
Loc: Toronto, Canada
I disagree with those saying it would create additional wear. I think the opposite would be true. Fuel injected engines run pretty lean at idle and will not cause fuel dilution, maybe with the exception of GDI and that's a big maybe, as many here believe. The oil and coolant temps will vary much, much less and the engine components themselves will see very little heat cycles.
Would this outweigh the extra cost in fuel? I don't think so because the vehicle is sitting and doing nothing. However in commercial applications, where the equipment can be operated by different crews/drivers 24/7, with only downtime for maintenance and repair, the engines do last longer with fewer break downs.
Edited by KrisZ (01/06/17 06:30 AM)
2015 Dodge Grand Caravan-21k miles.
2006 Mazda 3-155k miles
#4294688 - 01/06/17 06:37 AM Re: Leaving the engine run All night long (all night) [Re: veryHeavy]
madRiver Offline
Loc: New England
I have with my Civic to keep an 2500 watt inverter running to power my boiler and fridge during power outage.
#4294693 - 01/06/17 06:47 AM Re: Leaving the engine run All night long (all night) [Re: veryHeavy]
Matagonka Offline
Loc: NC
but why?
#4294695 - 01/06/17 06:51 AM Re: Leaving the engine run All night long (all night) [Re: veryHeavy]
bioburner Offline
Loc: Minnesota
I have talked to those in Alaska running diesels and yes because of -40 or worse. On the fly oil changes on the heavy equipment.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4294699 - 01/06/17 06:56 AM Re: Leaving the engine run All night long (all night) [Re: veryHeavy]
aquariuscsm Offline
Loc: South Texas,USA
Heck,keeping it running indefinitely=no startup wear! Engine will last forever laugh
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Pennzoil Platinum 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 0W20
#4294719 - 01/06/17 07:16 AM Re: Leaving the engine run All night long (all night) [Re: veryHeavy]
Bluestream Offline
Loc: Waterloo, ON
If you leave your engine always running you will save wear and tear on the ignition switch, and starter motor. They can be expensive if you ever have to replace them..
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#4294722 - 01/06/17 07:18 AM Re: Leaving the engine run All night long (all night) [Re: FordCapriDriver]
Danno Offline
Loc: Northern Ontario, Canada
Originally Posted By: FordCapriDriver
trolling
No seriously i don't know if you are trolling or if you are serious... i would never leave an engine running all night unless it was -50 degrees outside and i didn't have a block heater on a car, its a massive waste of gas, it creates wear on the engine, it's unnecessary pollution etc etc etc.
No trolling in his post.
I have seen -40C - without windchill and I don't live in the coldest areas of Canada. At that temp using a block heater may not be enough as the block heater does warm the coolant, but the oil pan is not heated That means a 15W-40 in a diesel will be like molasses. Good luck with starting at that point.
If you run a block heater, oil pan heater, and heated battery blanket, you will probably start, but with heavier duty trucks, you start running out of electrical power on a normal 15 AMP circuit to power all those accessories.
I was at a natural gas trucking conference a couple of years ago. Emterra, a refuse company in Winnipeg Manitoba (known as Winterpeg" in Canada) had launched a new fleet of NG refuse trucks. They could not get enough heat into the engines by plugging them in and had to resort to insulated engine boxes and run 20 AMP service.
They were experiencing up to 50% downtime before they took the extreme measures.
So yes, leaving your truck running to avoid a no start is a reality where it gets really cold.
Edit: Just looked up Emterra, they won't be getting the business after 2017.
http://www.cbc.ca/news/canada/manitoba/winnipeg-waste-contracts-1.3783784
Edited by Danno (01/06/17 07:27 AM)
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
#4294723 - 01/06/17 07:18 AM Re: Leaving the engine run All night long (all night) [Re: veryHeavy]
Bud Offline
Loc: Texas
Simple answer, no.
2016 Honda Pilot EX-L with NAV.....Mobil 1 0w20 AFE and Ultra XG7317
#4294731 - 01/06/17 07:31 AM Re: Leaving the engine run All night long (all night) [Re: veryHeavy]
ShotGun429 Offline
Loc: Dayton,Ohio
My 06 Crown Vic Police Car i bought used last year, must have idled alot during its service life, it has almost 7000 idle hours on it plus 105000 miles with no ill effects, but i dont let idle much any more.
#4294735 - 01/06/17 07:41 AM Re: Leaving the engine run All night long (all night) [Re: veryHeavy]
TiredTrucker Offline
Loc: Central Iowa
And something that never seems to be mentioned, a fuel fired coolant heater. Yes, they come in both diesel and gasoline varieties. Not cheap, but not terribly expensive either. Webasto and Espar are the two major brands and have been around for a long time. Can be set on a timer and when they start up, they can have an engine, even a larger heavy truck engine, up to 140F in less than an hour even at -50F outside temp after the engine has been shut off for 24 hrs. Uses less than 1/8th of a gallon of fuel from the vehicle tank to do it. And these thing can be plumbed in creative ways to also warm tank fuel (diesel) and the oil pan. So the old argument that "there is no plug in so there is no way to keep the engine warm with a block heater" doesn't fly anymore. For those that actually deal with cold issues frequently and not just academically, we have figured out how to get the job done.
We never seemed to have such a terrible time in the interior of Alaska when I live there for 10 years. Folks actually used the gray matter between their ears that they were given and some common sense which is sorely lacking nowadays.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
#4294738 - 01/06/17 07:49 AM Re: Leaving the engine run All night long (all night) [Re: madRiver]
Virtus_Probi Offline
Loc: New England
2500W is a nearly 200A load on your alternator...I'm sure it's fine as a peak load.
2014 Forester XT, 80500 miles
Last Change;
Valvoline Full Synthetic 5W30 d1G2
Tokyo Roki 15208AA170 filter
#4294759 - 01/06/17 08:18 AM Re: Leaving the engine run All night long (all night) [Re: veryHeavy]
Vikas Offline
Loc: NorthEast
Do the truckers leave the engine running when they sleep in their cab on the side of the road?
#4294768 - 01/06/17 08:31 AM Re: Leaving the engine run All night long (all night) [Re: veryHeavy]
RedOakRanch Offline
Loc: Central Coast California
There was a TV show where some guys drove Porsches across Alaska in winter and they did let them idle all night. If I remember right they didn't use use as much fuel as expected. I know a few people who drove home drunk and left there car running in the yard overnight. Still running with the radio on and the door open the next day.
1994 Ford Crown Vic 206k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 177k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 54k-M1 EP 0w20 $2/qt
#4294779 - 01/06/17 08:47 AM Re: Leaving the engine run All night long (all night) [Re: RedOakRanch]
AirgunSavant Offline
Loc: MD
lol- I've seen that!
#4294789 - 01/06/17 08:58 AM Re: Leaving the engine run All night long (all night) [Re: veryHeavy]
jacky Offline
Loc: wv usa
I have done work as a security guard and had to set in my truck (toyota tacoma) for 8 to 12 hours per night and left the motor running for 8 hours or so to run the heater.
at the time temps were below freezing
2001 chevy cavalier 148,000
