Any nano reefers here?
by RichardS
2 minutes 45 seconds ago
ARC remanufactured Power Steering Pump
by Pajero
8 minutes 57 seconds ago
John Deere "Easy Change" System gimmick
by SnowmanCO
12 minutes 13 seconds ago
Oz Planstic Bag Bans - not so green.
by Shannow
36 minutes 13 seconds ago
help me choose...
by chaindrive
59 minutes 57 seconds ago
France F1 Grand Prix
by DeepFriar
Today at 03:16 PM
Valvoline High Mileage with maxlife tech semi-syn
by bradtech
Today at 03:16 PM
Best additive in oil to clean sludge?
by ffgb
Today at 02:19 PM
Who is a Dirt Track regular?
by thooks
Today at 01:39 PM
eco plug oil plug video is restricted
by edwardh1
Today at 01:27 PM
Political comments
by ridgerunner
Today at 01:23 PM
My Ford orange turned pink
by BeerCan
Today at 12:45 PM
Any plants/garden experts?
by maverickfhs
Today at 12:43 PM
Internet Sales Tax O.K.ed by Supreme Court
by doitmyself
Today at 12:23 PM
Brake fluid for a '03 Volvo S60
by earthworm
Today at 11:22 AM
Oil Weight Change - Mid Production Cycle
by PolarisX
Today at 11:20 AM
Kia ATF - OEM, Eneos, Maxlife - TDS - DIFFERENT!
by Spddm0n
Today at 11:19 AM
Dillon Precision Is Simply The Best!
by 2015_PSD
Today at 11:17 AM
First OCI - 156k miles Prius
by Greg L
Today at 11:11 AM
Brake Squeal on Rear Discs
by BlitzPuppet
Today at 11:10 AM
wil892, Spddm0n, ronw1309, Suth31, yamahaboy125
65286 Registered Users
80 registered (aquariuscsm, 01rangerxl, Astro14, Bjornviken, AZjeff, Blaze, 10 invisible), 1594 Guests and 49 Spiders online.
65286 Members
67 Forums
285723 Topics
Page 1 of 2 1 2 >
#4292790 - 01/04/17 01:48 AM Recommend glue for sealing cracked fuel tank cover
zorobabel Offline
Loc: Anaheim, CA
My 97 Maxima has developed a gas leak which I traced to a hairline crack in the plastic fuel gauge sending unit, which acts as a cover for the fuel tank. The part seems rather expensive at $130+, so I want to try mending it.
Can you please recommend a glue that would work and hold up to gas and alcohol?
1997 Maxima 175k, Delvac 15w40, Wix 51315
2004 Corolla 189k, VWB 5w20 + SSS 10w40, MGL4967
#4292793 - 01/04/17 02:05 AM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
Ducked Offline
Loc: Taiwan
Long time ago I used leftovers from a glass fibre body repair kit, which is a polyester resin. IIRC that wasn't even supposed to work then (though it did) and petrol formulations have allegedly got more aggressive in the interim.
Now I'd probably try epoxy. If you can wait, maybe whatever you try you could test its petrol resistance first to avoid contaminating the surfaces with something ineffective, in case you find something better later on.
#4292795 - 01/04/17 02:37 AM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
rooflessVW Offline
Loc: North Carolina
PS 870 B.
It's expensive though...
"Zed's dead baby, Zed's dead."
#4292824 - 01/04/17 05:31 AM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
umungus1122 Offline
Loc: PA
VersaChem, Permatex, and others make gas tank specific repair kits. Since your looking to fix a plastic part instead of the steel itself, I'd look into a plastic specific bonding epoxy that is solvent(or at least gas) resistant.
'95 Chevy 1/2t 305 205k -DuraBlend 5w-20, Puro Gold filter
'89 Jeep Comanche 4.0 278k - GC 0w-30, Bosch LongLife filter
#4292827 - 01/04/17 05:39 AM Re: Recommend glue for sealing cracked fuel tank cover [Re: umungus1122]
sdowney717 Offline
Loc: Newport News, VA
I repaired a cracked filler tube neck in a 1998 Ford contour, leak stopped. That was years ago and it never leaked again.
They call it PL S30 nowadays. Gas has changed since then. I would still use it today.
I used Black Loctite PL Polyurethane roof and flashing caulk. You can put on a layer about 1/8 to 1/4 in depth.
#4292878 - 01/04/17 07:16 AM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
tc1446 Offline
Loc: Lexington, NC
JB Weld makes a variety of epoxies that should work.
'13 Accord EX-L 2.4L (100K) M1 & FU
'00 Ford Ranger 4.0L {65K} M1 & FU
'18 Polaris Slingshot 2.4L GM
'07 Kioti CK-30
#4292882 - 01/04/17 07:23 AM Re: Recommend glue for sealing cracked fuel tank cover [Re: umungus1122]
Bgallagher Offline
Loc: Boston, MA
+1
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
#4292908 - 01/04/17 08:01 AM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
Blkstanger Offline
Loc: Lakeside, CA
3M 8802 gas tank sealer
99 Jeep WJ 4.7 185,000 Maxlife 10w30, Fram Ultra.
#4292913 - 01/04/17 08:05 AM Re: Recommend glue for sealing cracked fuel tank cover [Re: tc1446]
fxrider Offline
Loc: Wyoming
been there done that. works great.
#4292958 - 01/04/17 09:22 AM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
Panzerman Offline
Loc: Port Orange, Florida
Playing with small engines and chainsaws for a hobby I have often found problems with cracked leaking gas tanks. I tried alot of epoxies and sealers, all of which were short term solutions. Nothing worked for long. What I have found that works forever and quickly is a soldering iron or wood burner. Melt the plastic back together. I just repaired a plastic chainsaw tank with a large crack and hole. Works like a charm. Not dangerous and pretty much permanent.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
#4293043 - 01/04/17 11:13 AM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
zorobabel Offline
Loc: Anaheim, CA
Thanks for the replies!
I'm favoring J-B Weld at this point. Should I go with the regular or the WaterWeld?
@Panzerman - I assume you just melt a bit on the surface of the plastic, and spread it over the crack?
#4293109 - 01/04/17 12:14 PM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
bigt61 Offline
Loc: Virginia
I'd get this - but likely any JB Weld will work.....
https://www.amazon.com/J-B-Weld-8217-AutoWeld-Repair/dp/B00R2CDUWE
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#4293110 - 01/04/17 12:14 PM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
sdowney717 Offline
You need to actually dig the tip into the crack, then force the material from the sides to fill and level.
It can work, works good on some plastics. Some it just does not work well, you get a weak result.
You can buy plastic welding rods, but the plastic types must match.
#4293112 - 01/04/17 12:17 PM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
Don't mess with heat and a gas tank.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#4293131 - 01/04/17 12:36 PM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
Johnny2Bad Offline
Loc: Saskatchewan, Canada
It all depends on the type of plastic you are dealing with. Some take glues well, some don't.
First choice for me would be a Putty Epoxy ... easy to apply, works on water wet or gasoline wet areas, and impervious to gasoline and alcohols. If you're dealing with certain plastics that won't glue up ... your option at that point is plastic welding (basically a form of heat melted plastic bond). Try Eastwood for the relevant supplies.
That may not work either ... some plastics get brittle if heated. But those are your basic options.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
#4293166 - 01/04/17 01:28 PM Re: Recommend glue for sealing cracked fuel tank cover [Re: JimPghPA]
Panzerman Offline
You can boil gasoline. It will not go off. I showed my son this camping. Regardless you will never ignite gas with a soldering iron. Just as the other gentleman said, you heat the sides of the crack and draw the Molton plastic in and smooth it out. Makes a permanent repair.
#4293170 - 01/04/17 01:29 PM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
Panzerman Offline
The plastic welders and plastic rods are terriable. They don't work well.
#4294152 - 01/05/17 01:41 PM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
Yah-Tah-Hey Online   content
Loc: Columbus,Nebraska
I wouldn't take short cuts with a fuel leak. Editor of our local newspaper was working about 12:30 AM Wednesday when one of the delivery help came rushing in to tell him his car was on fire.Vehicle was a total loss. He reported that he had been going to take car in to mechanic this week for what he thought was a coolant leak. Kaboom. Too lazy to open the hood.
#4294313 - 01/05/17 04:43 PM Re: Recommend glue for sealing cracked fuel tank cover [Re: Panzerman]
Ducked Offline
Loc: Taiwan
It MIGHT not go off. WILL not go off is something of a stretch.
If you were camping you were presumably using a naked flame?
To demonstrate how to boil petrol?
To your son?
One can of course get lucky.
OK Close Shave Petrol Story.....um...bit spoilt for choice, but I find this one hard to forget.
1800 Marina estate. Prequel to the repair described above. Filled up on the way home and the smell of petrol seemed more persistent than usual. Actually stopped to check, but it was dark and (of course) [censored] down and I couldn't see anything. Home late and forgot about it.
Next day woken by nosey neighbour who complains my car is leaking petrol down the street. Indeed. ALL the way down the street gutter, under lots of much shinier cars.
What to do? Have a couple of large jerricans, but have learned that siphoning petrol out of a tank really only works well in the movies. Decide to remove the tank and decant petrol directly.
EDIT: I'd better point out, for any petrol-boilers who might be reading, that most people would probably consider this was a somewhat dangerous thing to do, but everything is relative.ENDEDIT
Lying under the car in a small river of petrol, I'd unbolted the (still almost full) leaking tank and lowered it onto my chest, where it was soaking my overalls, and had just started to wriggle out with it, when the nosy neighbour (who'd complained about the leak in the first place) stuck her head down over the gutter to check on progress.
Did I mention she was a CHAIN SMOKER?
I couldn't look at first.
Then I looked and couldn't speak.
Then I spoke, but I had to be VERY polite to avoid agitatating the STUPID COW, since the ash didn't look very stable.
One of my nearer death experiences.
Edited by Ducked (01/05/17 04:49 PM)
#4294318 - 01/05/17 04:50 PM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
Nick1994 Offline
Loc: Phoenix, AZ
Same thing happened to my Camry last summer. Got a $50 fuel pump assembly from the junk yard. Working good.
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4298704 - 01/10/17 01:33 PM Re: Recommend glue for sealing cracked fuel tank cover [Re: zorobabel]
zorobabel Offline
Loc: Anaheim, CA
I ended up using the JB-Weld Waterweld putty. There were a number of hairline cracks in that plastic, in retrospect I should have bought the new part.
But so far (48hrs), no gas leak, no gas vapor leak or smell.
Page 1 of 2 1 2 >
