Fastest MIR ever!
by parshisa
15 minutes 29 seconds ago
2003 Dodge Dakota 4.7 V8 5-speed manual 4X4
by oilpsi2high
27 minutes 21 seconds ago
Eagles are one and done..
by LeakySeals
35 minutes 25 seconds ago
Switching Oil viscosity giving Quicksilver a try
by ad244
Today at 01:54 PM
2015 Yaris oil recommendation
by BIMMA
Today at 01:29 PM
Can any one tell me who make's this air filter?
by rollinpete
Today at 01:17 PM
38 years ago today
by dnewton3
Today at 01:07 PM
PQIA - Havoline HM Synblend 5w-30
by wemay
Today at 12:44 PM
Any 2015 Corolla owners here - coolant change Q
by NissanMaxima
Today at 12:20 PM
Thoughts on 2007 Hyundai Azera for $2700
by 901Memphis
Today at 12:18 PM
run straight coolant
by slomo
Today at 11:43 AM
How much liquid is needed to hydrolock an engine?
by zorobabel
Today at 11:14 AM
Intake manifold bolts torque 11ft lb
by Ndx
Today at 10:55 AM
Orange can of death
by WyrTwister
Today at 10:42 AM
Weird Master Cylinder Behavior
by artbuc
Today at 10:42 AM
Police were called, I was shoplifting!
by expat
Today at 10:41 AM
Mobile CI-4+ in Cummins 5.9L
by MileHi
Today at 10:19 AM
How & what pistol do you carry concealed?
by callbay
Today at 10:13 AM
High Mileage Transmission Change
by toreytlow
Today at 10:13 AM
Jamison Guardian Ammo
by BlueOvalFitter
Today at 09:53 AM
toreytlow, KOlan, Tenorman, DMperfection101, WiseOne
64257 Registered Users
110 registered (4WD, 2010Civic, 901Memphis, 69Torino, 14Accent, 7 invisible), 1712 Guests and 95 Spiders online.
64257 Members
65 Forums
278546 Topics
Page 2 of 3 < 1 2 3 >
#4292422 - 01/03/17 04:45 PM Re: Magnaflow mufflers - Straight through vs chambered [Re: emmett442]
buck91 Offline
Loc: West Michigan
Running dynomax ultraflow (straight through style) with o/r x pipe in the mustang. Same engine as the Vic... Love it, great tone and sounds mean at wot but otherwise rather quiet and tame. Had the chambered dynomax on a Vic before I found them obnoxious.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
#4292456 - 01/03/17 05:30 PM Re: Magnaflow mufflers - Straight through vs chambered [Re: emmett442]
440Magnum Offline
Loc: Texas
The final sound depends SO much on things other than just the muffler that its going to be almost impossible to predict.
I have the straight-thru Magnaflows on my '69 Coronet R/T. It has the factory high-performance cast iron manifolds (not equal-length headers), 2.5" tubing front to back, and an "H" pipe crossover ahead of the mufflers- as nearly a copy of the stock 1969 Dodge system as possible without buying an actual reproduction factory system. Obviously no catcons in 1969.
At idle and cruising, it has a deep-throated burble that sounds a lot like the stock Goerlich mufflers from 1969 did, maybe just a little louder. But as you open the throttle, there comes a point where the sound, for lack of a better description, "punches through" the muffling effect and it almost sounds like straight pipes. For that car (not daily driven) I absolutely freakin' LOVE the results.
Headers would probably change that a lot, since some of the "punch" effect is due to the stacking of exhaust pulses in the manifolds as opposed to equal-length tubes. Catcons would quiet it and possibly make it a little raspier by smoothing the low-frequency pulses through the tubes Removing the H-pipe would likely make it drone at highway speeds. My concern in a car like a Crown Vic would be that even with the catcons, the other effects (and especially if it doesn't have a crossover or H-pipe) would make it drone too much for your taste at highway speeds. But honestly, I've had worse drone on other cars with similar exhaust and chambered mufflers, so I'm not really sure that's necessarily going to be better overall.
Modern muscle car exhaust systems have a whole lot going on *just* to get a little loudness without highway drone- look at the combination of resonators and mufflers on a Challenger, Mustang, or Camaro (not even considering the active exhaust dampers on SRT and Hellcat Challengers, Corvettes, etc.). And the biggest disappointment I see on the forums when people change exhaust systems is that it causes drone.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
#4292526 - 01/03/17 06:44 PM Re: Magnaflow mufflers - Straight through vs chambered [Re: emmett442]
slacktide_bitog Offline
Loc: USA
If I ever wanted a cool exhaust and there wasn't a good catback available for it, I'd have a muffler shop do a custom exhaust with a glasspack for the resonator along with a Dynomax muffler smile
#4292550 - 01/03/17 07:06 PM Re: Magnaflow mufflers - Straight through vs chambered [Re: 440Magnum]
emmett442 Offline
Loc: Wisconsin
Thanks.
I'm not doing a system overhaul (it's in great shape, plus that's an expensive endeavor), just a muffler replacement. Retaining the stock piping, all 4 cats, resonators in the tailpipes...
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
#4292756 - 01/03/17 11:12 PM Re: Magnaflow mufflers - Straight through vs chambered [Re: emmett442]
vitez Offline
Loc: big sky country, Canada
I had a chambered Magnaflow on an Ford Expedition 5.4. It was nice and quiet at cruise but sounded great when you got on the pedal. I had Flowmaster 50 series on a Yukon 5.7 prior to the Expedition and the Magnaflow sounded definitely better.
OTOH I had some exhaust work done on a 1996 Jaguar XJ-R. It has a supercharged 4.0L straight 6 with a bizarrely complicated exhaust system: 2 manifolds (1 for 3 cylinders) feeding an exhaust pipe each to a pre-cat, which joint into one pipe to feed a main cat, then it splits into 2 again into a resonator each then 2 tailpipes. Sheesh. The pre-cats embolized into the main cat. We have no emissions testing here but visually they need to see a cat, so the muffler shop banged out the pre-cats and re-installed them, replaced the main cat with a glass pack muffler and reconnected it to the rest of the system. It passes inspection, and sound identical to before.
I said all this to suggest maybe a glass-pack isn't such a crazy idea. You already have 4 cats plus resonators so it's not like the muffler is doing most of the quieting.
I have CDO. It's like OCD except in alphabetical order like it should be.
#4292860 - 01/04/17 06:50 AM Re: Magnaflow mufflers - Straight through vs chambered [Re: bdcardinal]
Cujet Offline
Loc: Jupiter, Florida
Originally Posted By: bdcardinal
Straight through like a Borla sound the best on a mod motor IMHO.
Agreed. I also like the sound of the bigger (say 3") Walker Dyno-Max series of mufflers. Both the turbo and the straight through Ultra Flow.
FWIW, the Walker straight through "Ultra Flow" mufflers are the bargain of the century. The longer, the better and smoother the sound.
Walker makes a 24 inch long, 2.5" inlet and outlet, straight through welded muffler. It's sound is deep, strong and clean. Not hollow like a chambered muffler. Nice burble at idle, great bark at full throttle.
Check out this video for the sound of a modular engine with the Ultraflow muffler. Very nice indeed. He gets on it at the end.
https://www.youtube.com/watch?v=sQTcLG-m8Tk
Edited by Cujet (01/04/17 06:59 AM)
#4292861 - 01/04/17 06:53 AM Re: Magnaflow mufflers - Straight through vs chambered [Re: emmett442]
JustinH Online   content
Loc: Texas
I had a custom Bassani exhaust on a 96 Tbird with a Bullitt Mustang motor and vortech blower.
It sounded really nice.
A friend had the ultraflows on his Tbird with a GT motor and that sounded great also.
Not sure if the Borla setup is worth the cost.
'11 Hyundai Sonata GLS
'11 Scion XB
#4292936 - 01/04/17 08:42 AM Re: Magnaflow mufflers - Straight through vs chambered [Re: JustinH]
emmett442 Offline
Loc: Wisconsin
This is where I'm at with all of the cat-back offerings. Anything of quality is near $1k. Why should I replace the perfectly functional stainless factory piping when all I want is a little change in sound? Sure, maybe there are a couple of (small) horses to gain at WOT - but lets be honest here: the car is a slug with or without a cat-back. Unless it undergoes significant surgery, it always will be. On this car, I'm not willing to pay $1k for nearly in-detectable results that will only be noticed on a chassis dyno. On some of my others? Maybe. But not a Crown Vic.
The car is a cruiser. I love the sound of a V8 lazily motoring. I just want to be able hear it.
#4292949 - 01/04/17 09:14 AM Re: Magnaflow mufflers - Straight through vs chambered [Re: emmett442]
Bgallagher Offline
Loc: Boston, MA
I too loved loud exhaust when in HS and now prefer nice, quiet OEM. In HS I had a first gen explorer with a Gibson exhaust and it sounded nice. Had a low rumble at idle and wasn't bad in terms of droning. Try youtube for crown vic aftermarket exhaust systems. I bet there are a bunch of videos with different types of systems.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
#4293314 - 01/04/17 04:11 PM Re: Magnaflow mufflers - Straight through vs chambered [Re: emmett442]
440Magnum Offline
Loc: Texas
I put a Borla cat-back on my Ram pickup truck, even though it was expensive. I too just wanted a little more burble, but I also wanted dual side-exit exhausts to prevent burning anything I might carry on the hitch- like bikes or cargo on a hitch cargo platform. The Borla system had those features and sounds *perfect*, and should last as long as the OEM stainless system would have. But this is a fairly simple truck 2-into-1-into-2 system, and it replaced nothing particularly performance-oriented from the factory.
Would I do a cat-back on my SRT-8? No way. There's so much engineering in that factory system that I'd be foolish to think I could do anything substantially better with aftermarket parts.
#4294597 - 01/05/17 11:05 PM Re: Magnaflow mufflers - Straight through vs chambered [Re: emmett442]
wtd Offline
Loc: southwest Mo.
I have a duel out the back Borla cat-back on my 98 chevy K1500 and it sounds good. It does have a little bit of drone though and I'm not sure what the design of the inside is like.
I have a single side exit Flowmaster cat-back on my 98 K3500. This uses their 50 series muffler which is not real loud but this is a chambered muffler and it doesn't have any drone.
I have a GT500 cat-back on my 2014 Mustang GT. The over the axle pipes have no resonators like the factory OTA pipes do and the mufflers are the same ones used on the 2011-2012 GT500 Mustang but made by Ford Racing. These are supposedly chambered mufflers but I don't know for sure. This system sounds awesome with no drone and in my opinion is the exhaust that should have come stock on this car.
I have liked the sound of pretty much every Magnaflow muffler that I have listened to so I don't think you can go wrong there.
Wayne
Edited by wtd (01/05/17 11:06 PM)
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
#4294650 - 01/06/17 02:14 AM Re: Magnaflow mufflers - Straight through vs chambered [Re: emmett442]
carloz Offline
Loc: Fl
A local tuner told me that a straight-through design can give a bit more power than a chambered one, though the gain may not be too noticeable.
#4294769 - 01/06/17 08:32 AM Re: Magnaflow mufflers - Straight through vs chambered [Re: emmett442]
DriveHard Offline
Loc: Middle of Iowa
I'm a huge fan of the Hooker Aerochamber muffler. It is a straight through design chambered muffler. Aggressive sound, but less drone that many others. The GM 6.2L is known for being hard to quiet down. I have tried the following on my truck:
Banks muffler straight through with packing type (way too loud)
Flowmaster 50 series big block - drone on highway, and noticable performance loss
aeroturbine with resonator - drone on highway, and generally didn't like the sound
Hooker Aerochamber with resonator - aggressive sound, least drone so far, best performance as well
Do some searching around on forums and you will be hard pressed to find any negative comments about the Aerochamber. Do some youtube listening as well.
Smile, it increases your face value
2011 Silverado Crew Cab LT 6.2L/6spd
2013 Mercedes Benz ML350
2004 Yamaha FZ1
Elio...?
#4295100 - 01/06/17 03:39 PM Re: Magnaflow mufflers - Straight through vs chambered [Re: emmett442]
Yah-Tah-Hey Online   content
Loc: Columbus,Nebraska
Leave the OEM muffler on it and give the public a break. Why individuals think they need to make noise with a car is beyond me. frown
#4295229 - 01/06/17 06:52 PM Re: Magnaflow mufflers - Straight through vs chambered [Re: emmett442]
mlatour Offline
Loc: near Montreal, Canada
A while back when I drove a 2004 Dodge Ram 1500 4.7 liter V8
I had a front to back custom mandrel bent true dual exhaust with an 'X' crossover
and experimented with a few mufflers in the following years.
-Gibson
Quiet but were very restrictive at higher rpms versus the others listed below
(perhaps I didn't choose the proper size for my application)
-Magnaflow / straight glass packed design
Felt like the best top end HP, decently quiet a first but they do get louder over time, bad drone on the Hwy.
-Flowmaster 70 series / chambered design, one of they're quietest mufflers.
Best overall performance, quiet at idle, sounds 'just right' while accelerating, no drone at highway speeds.
But now I'm into leaving my vehicles stock and quiet,
as HosteenJorje suggested above, I've come to despise noisy cars/trucks driving by my house.
Edited by mlatour (01/06/17 06:57 PM)
