My flex pipe is bad and I have been looking into options. A Starla pipe is about $120. I can get a good used OEM pipe for $55. Is the OEM used pipe a dumb idea? I assume the Starla pipe is not stainless, and the OEM is?
Go for the OE part, it's cheaper, will fit better, and should last longer. Or get a CHEAP replacement of eBay, high zinc prime it then high temp paint it - more satisfying and cheaper too
